Technical Model A rear spring
Discussion in 'Traditional Hot Rods' started by junkyardgenius, Jan 25, 2026.
  1. junkyardgenius
    junkyardgenius
    from Kernow
    I,m running an A spring under the rear of my 34. Using 10 leaves and it gives a nice ride. Over the last year it has started to drop so I made and installed a spacer as a temporary fix. I can have the spring reprofiled ,could also add another leaf but don't want to spoil the ride quality. Any advice?
  2. alchemy
    alchemy
    If it was an original spring that started to droop, I’d think it might continue. Like it has something wrong.
    If it’s a new spring, maybe that’s as far as it will go. I’d think you could put a little re-arch in it and it would probably hold.
    But I’m no expert.
  3. '29 Gizmo
    '29 Gizmo
    from UK
    Yes...... Lots of tutorials on ebay on reprofiling springs using a hydraulic press.
    warbird1 likes this.
  4. Happydaze
    Happydaze
    New or old spring?
    Dismantled yet? Any clues?
    Chris
  5. 1946caddy
    1946caddy
    from washington
    Got any pictures? I'm having a hard time visualizing a Model A rear spring in a 1934 Ford. Unless you're talking about a Model A front spring on the rear and that would be too short.
  6. ALLDONE
    ALLDONE
    buy a new reversed eye super slider spring... doesn't get any better for a couple hundered bucks..
    Illustrious Hector likes this.
  7. Tim
    Tim
    from KCMO
    I’m also curious if it is an original spring or aftermarket.
    either way I would let it ride with the spacer until I was confident that it was done continuing to to settle. Then pull the spring pack apart and add some arch back to the main and maybe the next two leafs.
    I’d do it exactly the same as you reverse a main leaf in your garage but use the process to add some arch. Easily done. in an afternoon.
    junkyardgenius likes this.
  8. junkyardgenius
    junkyardgenius
    from Kernow
    Thanks for all the replies here. I should have said it's an aftermarket spring. I think it settled as much as it's going now. Had some econoline springs redone by a company here last year and they worked out great.
    Tim likes this.
