Technical Model A rear tube shocks
Discussion in 'Traditional Hot Rods' started by 30 A Ripper, Feb 15, 2014.
  1. 30 A Ripper
    30 A Ripper
    from Florida
    With the top bolted to the frame, Is there anyway to bolt the bottom end of tube shocks to the axle housing?
    Not sure whether the bolted connection could be made secure enough not to rotate under load...
    Would rather not weld on axle, bolt lower to wheel backing plate or attach to radius arms for various reasons.
    Thanks, ****
  2. Lazy Jake
    Lazy Jake
    There exist kits for mounting tube (airplane) shocks to both the front and rear suspension of Model As. The kit on my A bolts the top of the shock to the rear cross member and the bottom has a bracket with some longer bolts that replace two of the short bolts that secure the backing plate to the axle housing. The shock then mounts in the bracket. Simple and clean
  3. pasadenahotrod
    pasadenahotrod
    from Texas
    How about a picture of what you have got to work with?
  4. Can you modify a '46 - '48 tube rear shock mount? They bolt to the rear end and have the mount for tube shocks..
  5. 30 A Ripper
    30 A Ripper
    from Florida
    The backing plate to axel housing kits require a pretty complete dis***embly of the rear wheels to install the longer bolts. Since just trying to get somewhat ready for my first short tour with club, would rather get into rear brakes, etc later. I understand removing those rear drums can be a bear..
    Just looking for a simpler alternative and thought bolted lower shock mount on axel shaft housing would be the way to go. Concern here is forces imposed on those radius rods/wishbones connection.
    Looks to me like 46-48 tube rear shocks were welded to axel shaft housing and not bolted. Of course I'm no expert at searches <G>.
    Mine is just a stock 30 Tudor with missing H-lever shocks... The rebuilt H-shocks are pretty expensive for my taste. Have been advised that MGBs have cheaper and available lever shocks that might be adaptable. Seems like tube shocks are an improvement to the car's ride.
  6. Hitchhiker
    Hitchhiker
    I dont mean this as a dig on you, but it Sounds like you are trying to find a way to half *** it....do it right or don't do it at all.
    The 1946-48 lower mount bolts to the backing plate bolts. FYI. no welding required and the drums aren't nearly as bad as they sound.
  7. 30 A Ripper
    30 A Ripper
    from Florida
    Have done cars n planes but now in 70's and just want to do my first tour with this impulse purchase <G>. For a car that was supposed to be tour ready, it has been 2 steps forward and 1 back.
    In any case it will be my decision how to proceed with the repairs, etc.
    Did find that there was a Houdaille tube shock conversion kit for 35/36 Ford rear axles that looks interesting.
    Thanks, ****
  8. Hitchhiker
    Hitchhiker
    I put 3000 miles on my A pickup last year with no shocks....thats always a option;)
    Im sure you will figure out something that will work for you.
  9. mike bowling
    mike bowling
    I did a Model A roadster over a couple of years ago ; stock- mech. brakes, banger etc.. Front end was rebuilt, steering box,new brakes, brake rods all R&R'd. When I got the car, it didn't have shocks with it, and after I found out what they cost, I decided to try it without them.I put '35 wires on with 6.50 16 bias ply tires, and it runs out fine.Corners nice at top speed (45mph) and is a lot of fun. Good luck with yours. Mike
  10. Jimmy2car
    Jimmy2car
    from No. Cal
    Look for MGB rear shocks on Ebay. Easy bolt up fix that works real well. Made by Lovejoy or Armstrong
