Model A Rear Wheel Studs?????
Discussion in 'The Hokey Ass Message Board' started by muffman58, Nov 2, 2005.
  1. muffman58
    muffman58
    I want to replace the rear wheel studs in a 31 Model A rear end. I am wanting to put a wider wheel on [ aluminum ] and the orignal studs are to short! Any ideas on what you guys use? Any part numbers? Thank`s for the help.
  2. alchemy
    alchemy
    You will find it WAY EASIER to get the correct lug nuts. Just finding the stock size studs is bad enough, but finding some longer? No such part.
    Model A studs were swedged (swaged?) into the drum. Do you know the proper proceedure for R&R?
    http://idisk.mac.com/forever4/Public/pages/swaging.htm
  3. muffman58
    muffman58
    BTTT- Any Others?
  4. LIMEY
    LIMEY
  5. Bruce Lancaster
    Bruce Lancaster
    There's a good drawing with dimensions in the '28-48 Ford catalog, showing every importat dimension of every Ford wheel stud. Take that down to the store and ask to root through the Dorman catalog and see if anything is available for sure.
  6. muffman58
    muffman58
