Model A rearend question
Discussion in 'The Hokey Ass Message Board' started by Low Fat 38, Mar 18, 2012.
  1. Low Fat 38
    Low Fat 38
    from Norton,Ma
    Stock '30 Model A rear, '39 Ford pass car trans. I'm having a problem getting torque tube in u joint. Any tips, tricks, will be appreciated.
  2. Dont understand the question.... could you rephrase that please?
  3. When I did this I also had trouble getting the u-joint to go on the drive shaft. I ended up taking the u-joint off of the trans and putting it on the drive shaft and marking it. Then I bolted the u-joint back on the trans and was able to line the drive shaft up alot easier.
  4. pasadenahotrod
    pasadenahotrod
    from Texas
  5. tjmercury
    tjmercury
    That sounds pretty much like the way we done it, and it is a lot easier if you enlist a pair of helping hands as well.
  6. Low Fat 38
    Low Fat 38
    from Norton,Ma
    Thanks guys, I'll give it a try.
  7. Low Fat 38
    Low Fat 38
    from Norton,Ma
    Thanks 62pan it worked like a charm.
