Technical model a recess firewall
Discussion in 'Traditional Hot Rods' started by sdluck, Oct 27, 2019.
  1. sdluck
    sdluck
    I have a 29 model a gl*** car,it has a partially recessed firewall with a sbc,I cannot remove the dist because it hits,without disconnecting the motor mounts and misc to lower it enough to remove it.What have you guys done
  2. seb fontana
    seb fontana
    from ct
    Use a SBF; dist in front.....
  3. gimpyshotrods
    gimpyshotrods
    Which distributor do you have?
  4. sdluck
    sdluck
    I have tried a stock chevy point and bought an accel points 2 piece dist.
  5. jaw22w
    jaw22w
    from Indiana
    It's that old physics thing again. Two objects can't occupy the same space at the same time.
    I have one of those Accel 2 piecers stashed away somewhere myself. I haven't seen it for a long, long time. Doesn't the top part come off? Will it still not come out if you take it apart? My firewall is notched for the distributor. I still have to take the cap and rotor off for it to come out. You might have to make room.
  6. sdluck
    sdluck
    No it almost clears. I am running the motor with a carb but after it is broken in I want to put Hilborn Mech injection,but that's another story.
  7. gimpyshotrods
    gimpyshotrods
    Don't sell that carburetor or manifold.
    upspirate and Nailhead Jason like this.
  8. gimpyshotrods
    gimpyshotrods
    When I have "missed the mark" on leaving enough clearance, I have turned to hiding the fix in plain sight.
    In your case, I would make a bolt-in polished stainless steel recess, with a nice set of counter sunk, evenly spaced fasteners.
    If you cannot fix a ooopsie, make it look intentional.
    I am still working on it, but the recess in my center console, for a hand to go around the parking brake handle, is a stainless steel serving tray, bolted to the underside.
  9. goldmountain
    goldmountain
    slack likes this.
  10. gimpyshotrods
    gimpyshotrods
    Sure, but it would need to be bonded-in, and the car is already painted.
  11. DDDenny
    I've often thought one of these would be pretty easily adapted as a bolt-on recess for distributor clearance, I also considered using something similar for a footwell/rest in the fibergl*** floor for the gas pedal in my roadster.
    https://www.highway99hotrods.com/Blisters/orderb.htm
  12. sdluck
    sdluck
    Good idea DDDenny,I will see if I can do something like that
  13. blazedogs
    blazedogs
  14. blazedogs
    blazedogs
    A Issue when going with a recessed firewall in a model A There will be a issue with your steering column it will fall at the edge of the firewall Ask me how I know gene in Mn
  15. Mr48chev
    I think my buddy's old (old in as used to have 40 years ago) was that way with the wheelbarrow used for the indent in the firewall. It used to be fairly common but guys weren't pulling the distributors very often either.
    Years ago I saw photos of one that was a lot more race car than street car that they had made a trap door or removable door over the distributor so it could be lifted out.
  16. sdluck
    sdluck
    Steering is in the car,has been for years,partial recess of firewall.
  17. sdluck
    sdluck
    I almost put a front drive dist in it .
  18. baspinall
    baspinall
    from SE PA
    How about a picture of your dist. area.
  19. sdluck
    sdluck
    Car is about 20 miles away,I will take one today
  20. Cree
    Cree
    from Montana
    X2 Gimpyshotrods approach...Part of a headlight bucket can provide a nice shape.
    gimpyshotrods likes this.
  21. Blues4U
    Blues4U
    from So Cal
    Same thing here. Drain the radiator and pull the hoses free, pull the motor mounts and lower the front of the engine till the distributor clears.
  22. Blues4U
    Blues4U
    from So Cal
    Exactly. How often do you pull the distributor?
    46international likes this.
  23. Chappy444
    Chappy444
    A guy I know did this on a '32 sedan...…..
    Rice n Beans Garage likes this.
  24. solidaxle
    solidaxle
    from Upstate,NY
    I'm not sure where your having clearance problems without a picture. If it's the top, how about a Mallory distributor with a Marine cap.
    Mallory 221B Distributor Cap (Flat Marine)
  25. HOTRODPRIMER
    HOTRODPRIMER
    You can always make a piece of aluminum notched with enough room to remove your distributor, then make a flange to fit over it then pop rivet or screw it in place. HRP
  26. sdluck
    sdluck
  27. X-cpe
    X-cpe
    That was my mom. No matter what she had to change, redo or modify (not automotive), she would tell you, "That's how I planned it."
  28. solidaxle
    solidaxle
    from Upstate,NY
    The picture does not help without the motor mocked up on the frame.
    It's a homemade firewall, why not just cut away?
  29. k32t
    k32t
    from Hog town
    may be something like this
  30. sdluck
    sdluck
    Thanks I will try to get some better pictures
