Model A Roadster/Coupe Size?
Discussion in 'The Hokey Ass Message Board' started by Slammed88, Sep 18, 2007.
  1. Slammed88
    Slammed88
    from Canada
    I know this might seem like a stupid question, but do you know if someone around 6'1 and 245-ish lbs could fit comfortably in a Model A roadster/coupe? The reason I ask is because I was thinking of building one, but if I'm not even going to fit in the thing, there's really no point. Haha!
    Also, does anyone know how much more interior space a coupe has as opposed to a roadster? I might want to consider hacking the roof off of a coupe if it'll give me any extra room. :D
    Thanks!
  2. Stovebolt
    Stovebolt
    I've got a 29 coupe w a stock firewall, and it has 45" from firewall to parcel shelf. BTW its the same length inside as a 32 roadster :D
  3. pasadenahotrod
    pasadenahotrod
    from Texas
    The coupe and roadster have the same interior space except the vertical part!
  4. Slammed88
    Slammed88
    from Canada
    Do they really? I was sure the coupe was bigger. Good to know. :D
  5. Elrod
    Elrod
    Coupe is bigger. Distance from top of decklid on a roadster to the seat is farther, therefore pushing the seat forward. Roadster doors are much much smaller than a coupe. The leg room in a roadster is less than in a coupe.
    A cabriolet is a convertible that has the legroom of a coupe. They are rare though. How about getting a sport coupe, making a top that folds down and you have a coupe with no roof, without cutting the roof off another nice coupe. If you are going to cut the roof on a coupe, just chop it and put the roof back on lower. To many ******* coupes that just look wrong.
  6. Slammed88
    Slammed88
    from Canada
    I actually have a line on a cabriolet. It's a little more than I want to spend, but if I can fit into it, that's alright. :D
  7. easyrider47
    easyrider47
    I'm a big guy, 6'1", 290#. The only trouble I have with my roadster is the doors are so short, I have to kind of step up into it and sit down. My buddys souple seems easier for me to get into, but then there's nothing like a roadster.
  8. Slammed88
    Slammed88
    from Canada
    Thanks! Does the interior feel cramped at all when you're driving in it? Is it a tight squeeze? :D
  9. docholiday72tx
    docholiday72tx
    I have the back section of a 28/ 29 cabriolet. What doors and cowl do I need, or will any of them work?
  10. No_Respect
    No_Respect
    from So-Cal
    I'm 6'0 and fit in my roadster just fine but the seat is pushed back far as I could. Lance from lance hot rod shop he is at least 6'2 and had that heavy chopped coupe[​IMG]
