Model A roadster is a roller *updated 12/10/09*
Discussion in 'The Hokey Ass Message Board' started by Chris, Nov 29, 2009.
  1. Chris
    Chris
    Engine is a 34, ****** is a gen-u-wine 39
  2. lorodz
    lorodz
    lol ..i was wondering cause i got a line on a nice clean 36 flattie for 350 complete was just pulled out of the car but the guy doesnt have trans so im trying to find out what trans will fit to it
  3. Chris
    Chris
    Any ****** 32-48 V8 will fit...even light duty pickup 3 speeds up to 52 will work. Late 36 engines had shell bearings in em as appossed to babbit. If it's a true 36 engine (water pumps in heads and NO block off plates in block were later pumps go) and has shell bearings, I'd buy it in a heartbeat. Even a decent running babbit engine is worth that...specially if it still has the 97 carb on top :D
  4. ironandsteele
    ironandsteele
    chris, keep the updates coming!
  5. lorodz
    lorodz
    only thing it dosent have is the car and starter ..i have 2 97 aklready from a older project i just need a starter and trans but i might have a line on them ..but thanks for the info ya build is getting there i swear our cars look like twins ...keep it up
  6. Chris
    Chris
    Thanks! Starters are all the same for V8's 32-53
  7. hotrod-40
    hotrod-40
    Glad to see you are having stuff chromed, while I am spending late nights insulating the roof on your shop!
  8. antiqueautomike
    antiqueautomike
    from Spokane
    V-8 60 starters are different.
  9. Chris
    Chris
    Yes Mike, you are correct!
    Worked on the car a little today. Again, using all early Ford parts I am using 40-up style clutch linkage. Beings thats what the F-1 trucks use, it was pretty strait forward. I also had to re-drill the pedal mount holes a little up and over twards the center. Then just bolt em up, hang the linkage from the ******, and that gives you the spot to mount the pivot ball. The ball will need to be shimmed down, but the nuts in the pics will work for now. I gotta get a throwout bearing and install it, then I can dial in the likage. After that, mount the body again, make sure pedals and such clear...then it will be ready to come all apart until it is put together for good!
  10. Low Fat 38
    Low Fat 38
    from Norton,Ma
    Chris, Do you Plan to weld up the crossmembers or trust Henrys rivets?
  11. Don't forget to drop your pedals and all your linkage off at the plater, they should have it done by the time it's ready to go back together for good.:D
  12. Chris
    Chris
    Billy, I'll have to wait a bit as I think I'm just gonna have the whole frame chromed. I mean, why stop with the shifter? Can you come over and help me and Russ hand sand and buff it ;)
  13. AV8-Rider
    AV8-Rider
    Ohh yeah. Nice update Chris. I've been off here for a while and one of the things on my list stepping in, where to chech out if you got around to this V8 update.
    Sure is inspirational and fun.
    The car will be nice.
    Envious of that hood of yours.
    Paul
  14. lorodz
    lorodz
    hey chris can i get a quick steering tech ..im going with the f1 box ..but didnt understand what you ment bye usinf the model A flange ..im shure it self explanitory cut the flage off the model A steering box and weld to f1 id like to see how you did yours i looked in the tardel book i have (how to build a tradditonal hot rod) but didnt see it ..thanks
  15. Chris
    Chris
    I'll get some pics tomorrow for ya on the box, my Tardel book shows it on page 42. Picture kinnda ****s, though!
  16. Mr48chev
    Most regular full service machine shops should be able to swap ends and get it right. It would mean that you had to pay someone to do something but the results may be worth it.
    Side note: I should have read post 161 before posting the above. It looks like you may have it handled.
  17. rat seeker
    rat seeker
    Awesome Thread I love it
  18. Impressive build. Really like the solution you found to your drive shaft problem. Innovative. Mike and Vern will have to add an addendum to their book when you are done.
  19. Chris
    Chris
    Here you go, pretty basic. Simply cut off the F-1 mount flange and do the same to an A box...toss the F-1 flange aside and use the A flange on the F-1 box. Gotta tapper each side for good weld penetration. Also rebush the housing when done. The book goes into great detail in this. Hope this helps.
  20. Chris
    Chris
    Yep, got her all handled!
  21. Chris
    Chris
    Thanks but I dought it...this is pretty backyard basic. I honestly have no clue what I'm doing and just wingin it as I go ;)
  22. lorodz
    lorodz
    Thats it ..omg that s easy as **** ...as we have all said before you make it look so easy ....thank you sir ...srry about the caps
    1 more thing where do i get a new bushing from.. and which one do i use the model A bushing or the f1 bushing
  23. Chris
    Chris
    I don't know on the bushing, I would guess from any Ford restoration supplier or bearing supplier. The ID/OD appears to be the same, so a bushing for either would work...but I would go with an F-1 only because thats the box and sector your using. They may even be the same bushing for all I know.
    Cool thing about this whole set up is that you can also pick the angle in which the steering shaft comes up to the dash. Get it lined up were you want it, tack it, and then weld er up.
  24. lorodz
    lorodz
    perfect ...i really appreciate all the help ..i want this car to come out great its the last one im going to build.my dad p***ed away and it was the last one he had seen before that so i want it perfect...thanks again...now back to the regular scheduled build.
  25. Chris
    Chris
    Not much going on as of the late, been out of town. But, worked on getting some 97's stripped and cleaned, rebuilt them tonight and also cleaned up the intake manifold.
  26. lorodz
    lorodz
    nice and clean man ...looking good
  27. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    PM-7???? Nice Chris!!! I buddie of mine just bought one from a feller for $100 which I thought was a score and a half. I can't wait till I can get started on my 59a. I have 2 rebuilt 97's sitting on the shelf that are just itching to be used!
  28. Chris
    Chris
    Yeah, it's a PM-7. Your buddy SCORED dude! I'd ****in pay 100.00 all day long for these things...job or no job :D
    Tonight I rebushed the clutch fork shaft bosses in the trans case, installed a new shaft, pressed on a new throw out bearing, and bolted the whole shibang up. The hooked the clutch pedal up and wouldn't you know...it works! Next step is dropping the body on for (hopefuly) the last time before the ch***is is painted.
  29. willie57
    willie57
    from wisconsin
    thanks for posting your buid I have learned a lot reading it. I have a 29 coupe and am thinking about using a flat head instead of a small block chevy. Your workmanship is awesome.
  30. Chris
    Chris
    Wow thanks! I think my workmanship is pretty ****py. It gets the job done but I have a ton of room for improvement! I learn everytime I work on something.
    Flathead before SBC anyday!!!
