Technical Model a roadster w/s
Discussion in 'The Hokey Ass Message Board' started by oliver westlund, Sep 8, 2024.
  1. oliver westlund
    oliver westlund
    Okay, hate to have to make a special post for this but it will likely help others. Woyld be nice to have a break down of stanchoin height and w/s frame heights that correspond. For example, I just ordered 32 upper stanchions thatre chopped 2" what size w/s frame should I order?
    scotts52 likes this.
  2. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    Do you have a standard, or a delux...?
    oliver westlund likes this.
  3. wheeldog57
    wheeldog57
    Mine is a 28-29 so I don't know if it helps but at 6ft 5in I made a windshield frame out of 3/4" tubing and propped it up on the cowl then fabbed up stanchions to fit said frame. Once I was happy I cut an original w/s frame and had gl*** fit to it. 20220819_095959.jpg
    oliver westlund and hfh like this.
  4. 1935ply
    1935ply
    from peyton,co
    A 2" chopped deluxe 30-31 windshield. It's better to get the frame then cut and reweld model a stanchions. If you are going to run a top and plan on leaning the windshield back at all the nubs for the header to fit on will be at to much of an angle to the rear, so you would need to cut and rotate the tops of the stanchions. cutting stock ones you can get the length and angle you want.
  5. oliver westlund
    oliver westlund
    The car is a deluxe but the upper stanchions as I said above are 2" chopped 32 stanchions so that changes the formula a bit
  6. oliver westlund
    oliver westlund
    So the 32 upper stanchions and the 30/31 upper stanchions are the same length? And 2" chopped is 2" chopped regardless? The reason I am asking is I would like to order a chromed w/s frame so getting the correct height is important!
  7. IIRC, the 1932 and 1930-31 Ford upper windshield stanchions are the same height. And as you say, 2" is 2".
  8. oliver westlund
    oliver westlund
    Awesome! Thats the info I needed! Thank you
  9. oliver westlund
    oliver westlund
    I guess to be clear...30/31 deluxe upper stanchions and 32 stanchions are the same? So as stated above, a 2" chopped deluxe frame is whats needed
  10. Automotive Stud
    Automotive Stud
    I ordered 3" chop '32 stanchions for my '31. I had talked to Sid Chavers about a bop top and he swore up and down that it would be less than a 3" chop on an A, but I had my deluxe windshield and cut it down to fit the stanchions, and I had to cut exactly 3" out of it. It's easy to cut down an A windshield frame without damaging the chrome.
