Model A roof panels?
Discussion in 'The Hokey Ass Message Board' started by MIKE47, Nov 6, 2007.
  1. MIKE47
    MIKE47
    from new jersey
    Does anyone make steel roof panel inserts for model a that are "ribbed" ? I have seen smooth steel ones but none that have the ribs or beads in them. Any leads? or am I gonna have to make my own?
  2. SinisterCustom
    SinisterCustom
    Station wagon roof........
  3. MIKE47
    MIKE47
    from new jersey
    any in particular? I was thinking a mini-van or something like that. I'd like to not have to do much reshaping if I can avoid it.
  4. Candy-Man
    Candy-Man
    Early Chrysler mini-van roof....
  5. Von Rigg Fink
    Von Rigg Fink
    from Garage
    I got a list of about 5 or 6 at home i will try to pm you tonight
  6. chickengeorge
    chickengeorge
    I've seen Vega wagon used. Nice short, narrow set of ribs.
  7. Dirty Dug
    Dirty Dug
    I think ribbed roof panels look out of place on a hotrod, more of a street rod thing to me.
  8. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Mike theres one in my list that doesnt have the ribs, is that what you want?
  9. I got mine at Howell Sheetmetel in Texas
  10. rumblytruck
    rumblytruck
    small Jeep Cherokee, 80's up.
  11. MIKE47
    MIKE47
    from new jersey
    I'm not incapable of making my own, just looking to put in as little labor as possible. Yes I could make one from scratch and roll beads in it but why do that if some manufacturer already did the work for me. Also I am from NJ which limits the amount of bone yards that I can cruise around in and take measurements. Closest place around here that'll even let a guy go out in the yard is like 35 miles. And it's mostly late mode stuff. Thanks for the leads so far guys. It'll give me a something to look for. Thanks, Mike.
  12. Choptop
    Choptop
    ribbed... for her pleasure.
  13. floorjacks50
    floorjacks50
    from napa
    i've seen volvo 240 roofs used on a couple
    coolest one i saw, 1960 ford falcon hood, cut down and backwards so the little scoop was in the rear.
  14. SinisterCustom
    SinisterCustom
    Another one to consider.....the hood of a '57 Ford Pickup......
    Street rods have been around since the late 50's........a car show cl*** of the day......
  15. flamedabone
    flamedabone
    Mine is an 03 Mazda Millenia. I agree, it is a bit street-rody, but it's too late, the ****er is on there.
    -Abone.
  16. triplexkustoms
    triplexkustoms
    what roofs are on your guys lists? we s**** 25-30 cars a week and i'm sure i could grab some roofs.
  17. no55mad
    no55mad
    Question - I've heard newer cars (80's on up) have the thin hardened sheet metal that doesn't weld very good. Any of you experienced this?
  18. Reds 29
    Reds 29
    I used a 72 Vega stationwagon roof. I had to do some reshaping on the sides as it had a slight roll to the sides and didn't quite match the contour of the Model A. I heard of using a Chrysler mini-van or a mid 80's Olds Cutl*** wagon on a Model A Sedan, although I haven't seen this one.
    Red
  19. A Chopped Coupe
    A Chopped Coupe
    Got mine from Howell's also.
  20. tj
    tj
    Used an early 70's Ford wagon on a 31 sedan. Ribs were rounded - most of the vans I looked at the local U-pullit were squared ribs.
  21. Sutton
    Sutton
    from BTR
    59 Impala wagon roof
  22. HHRdave
    HHRdave
    from So Cal
    Howell's sheetmetal in Texas has smooth and ribbed. Call Ryan.
  23. duwty
    duwty
    i really like the ribs
    just look at pics on the web of later model rides (auto trader etc...) just to get some ideas
    almost any type of vehicle with a long roof has the ribs for support, wagons, vans, suvs, 4 door trucks
    a newer ford f150 has some cool ribs about 2 inches wide, saw one laying around at the body shop that i work at but it had the sunroof hole
  24. flathead31coupe
    flathead31coupe
    from indpls, in
  25. chopped30
    chopped30
    from ohio
    I used a smooth roof on my coupe. The donor was a 70 cougar (I think mustangs are the same) it fit nicely and the curve was dead on. I am going to use ribs on my Vicky.
    Ollie
  26. Misfit
    Misfit
    from Upstate NY
    That roof is wicked. 1 in a million to find a 59 impala around here though.
  27. bcharlton
    bcharlton
    from Buffalo NY
    Please help me understand this. What are the mian differences between a "street rod" and a "hot rod". The roof on my 31 olds is filled with a smooth roof. That is considered more hot rod than street rod? Can anyone please help me understand the differences so I don't look like an A- hole next time I post something on the HAMB.
    BC
  28. bcharlton
    bcharlton
    from Buffalo NY
    p.s
    No need to post "too late"
    BC
  29. DeepSouthRick
    DeepSouthRick
    I cut the roof out of a 75 Ford Econoline, before it went to the crusher. It was handy and free...
  30. Von Rigg Fink
    Von Rigg Fink
    from Garage
    wish there were more 59 impala wagons out there..i would love to see my roof look that cool..too long to search for somethin like that in these neck of the woods..still wicked enough to wait ..maybe!?
