model a ,s with hemi,s
Discussion in 'The Hokey Ass Message Board' started by aircoup, May 24, 2013.
  1. Cross Rodder
    Cross Rodder
    tjet,
    Here are some pics of the throw out bearing linkage. Its all old school and stiff but works pretty well. Offy adapter, early for peddles, early ford stock throw out bearing. I have a 10" clutch & pressure plate so I has to bevel the inside edge of the Offy adapter for clearance and enlarge the hole a bit for the linkage arm. Also had to grind the 34 ford trans case for pressure plate clearance where the case buldges for the throw out bearing pivot shaft. The last photo is of when I had a small block hooked up but you can see the linkage well which is the same.
  2. tjet
    tjet
    Cross Rodder - thanks for the details.
    On your extended bell hemi, did you need to cut the bell for the clutch fork linkage? I have a hot heads Muncie adapter that's "flat". I would need to cut a notch in the bell about 4"x6" & use a early vette fork & Z-bar.
    I plan on dropping my 52 331 & 4 speed into a generic T=bucket kit, like the ones that speedway sells. I want to make sure there's clearance for the extended bell + clutch linkage + pedal ***y. It looks like my gas pedal will be on top of my bellhousing (partially) Here is another pic of a t-bucket kit - see how tight it is?
    Noland has a similar build to yours, but he installed swinging pedals, whereas you are using an under-the-floor arrangement. I think yours would give me more clearance...see below
    http://www.jalopyjournal.com/forum/showthread.php?t=647364&page=9
    Anyway - sorry to hijack. Just wanted to pick your brain - dont want to reinvent the wheel
    Here's what I'm thinking about
    http://www.nehrspeedcraft.com/T14.html
  3. I'm not sure this counts being it's just in the Thinking stage but I do have it all, Well mostly. If I just had more time.
    The Wizzard
  4. So-Cal Speed Sacramento
    Alliance Vendor
    from Sacramento
    beautiful!! you're winning at life, sir. :eek::eek:
  5. aircoup
    aircoup
    sure it counts they all do.....:cool: good luck with it
  6. Some A's with hemis we have built over the last few years..
    Hiltons'
  7. 39ChevyBob
    39ChevyBob
    My buddy Frank's.
  8. 23buckethead
    23buckethead
    from Kokomo,in
    A newer picture of my 241 Red Ram ImageUploadedByH.A.M.B.1370209380.903664.jpg ImageUploadedByH.A.M.B.1370209393.554781.jpg
  9. EARLYHEMIBILL
    EARLYHEMIBILL
    from ?
    My buddy's 31 with a 341 under construction.
  10. John Milner
    John Milner
    from Oklahoma
    Here is mine. It is a '56 354 factory 2x4 engine out of a 300. I have a muncie transmission behind it and a Ford 9 inch rear.
      90.7 KB
  11. TexasSpeed
    TexasSpeed
    from Texas
    I'm surprised no one's mentioned Jimmy White.. One of my top favorite Hemi-powered As of all time.
  12. Cross Rodder
    Cross Rodder
    Sorry tjet, been away from the HAMB for a while. No cutting required for my little Ford 3 spd. I would try not to cut that bell if possible.
    CR
  13. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    DeathsDoorStep........sitting and getting dusty..392 w/ 354 heads....At times I feel like it has been taken away from me, hard to explain and silly.........Littleman Dave
  14. VintageFordDan
    VintageFordDan
    from Alabama
  15. Just wondered what the "sweet spot" is with the Hemi engine. That is, is there a particular Hemi that guys find best suits these kind of cars?
  16. How about showing some full fendered Model A's with Hemis?
  17. hemi rodder
    hemi rodder
    from NB Canada
    this summer
  18. Bump this back up
  19. The37Kid
    The37Kid
  20. 392modela
    392modela
    Working on mine yet with a 392,
  21. Dog_Patch
    Dog_Patch
    As far as which one fits better, the Desoto is shorter by a little so the grill and radiator can be back a little more on the Desoto.
    330 Desoto version :
    392 version:
  22. mikew
    mikew
    Here's mine.
  23. roseboystoys
    roseboystoys
    This is ours. 325 Dodge D500 Hemi...About the same weight as a SBC. Backed by a GM 200 4R with Lightning rod shifters...
    [/ATTACH]
  24. Futura63
    Futura63
    from N/W ohio
    Dam , my brothers been after me to build a shop truck "29" A . He thinks it should be a V8 Flat head , Ive been dreamin hemi . Now that I only see 1 hemi truck in 3 pages of posts I think HEMI wins .
  25. 392modela
    392modela
    Sent from my SCH-R530U using H.A.M.B. mobile app
