Hot Rods MODEL A SADDLE TANK PROBLEM....
Discussion in 'The Hokey Ass Message Board' started by 2FORCEFULL, Jul 30, 2024.
  1. ALLDONE
    ALLDONE
    so here's my fix....
    splitting and moving the vents to the wheel wells.. and adding a filter on each...
    taking out the T and putting an electric switch over.. the T is -6an,... I got 2 -6an 90's with 3/8''hose barbs. so I can hook to the switching valve and also a -6an straight to hook to the fuel pump line
    '28phonebooth likes this.
  2. ALLDONE
    ALLDONE
    so am I on the right track???? also my thinking is that when theres no power to the valve,,,it still pulls off one side... then when it gets power it closes that side and opens the other???
  3. ALLDONE
    ALLDONE
    UPDATE.... GOT ER DONE!!...
    the tank switching valve worked great in place of the "T"... ran a 18 ga. wire to the dash
    pulled the tank switch and it was not the 6 spade, only 3 and found that all it did was tell the fuel in each side......... so I added another 2 spade on / off toggle... so now... in the right position the switcch is off and it runs on the right tank...to the left, the switch is on and pulls fuel from the left tank.... going down the road I can switch to each tank to see how much fuel I have in each tank and not disturb the switching valve..
