Model A Sedan Rear end
Discussion in 'The Hokey Ass Message Board' started by RAJO Special, Aug 30, 2007.
  1. RAJO Special
    RAJO Special
    from Utah
    What are my choices for a rear end on a 29 Sedan?
    I would like to run open driveline, and a non-banjo rear.
    I see several guys running an S-10 rear, are they using 2wheel or 4wheel and from what years.
    Also if I go Ford 8", from what vehicle to get the right width?
    Thanks,
    K
  2. Deuce Roadster
    Deuce Roadster
    Most rodders use the V8 5 lug Maverick rear end under fendered Model A's. They are 56 inches wide ... measured this way.
    If you are going fenderless ... a little wider rear end is OK and if you are channeled ... they are almost necessary.
  3. Firecracker
    Firecracker
    I think that an s-10 rear end from the 80s will work. Also, you should try to finda rear end off of a Nova.
