Hot Rods Model A side apron height.
Discussion in 'The Hokey Ass Message Board' started by grumpy65, Sep 4, 2018.
  1. grumpy65
    grumpy65
    Hi all,
    Chasing a measurement for the side splash aprons on a model A so I can work out my ground clearance. What is the dimension from the top of the frame to the bottom of the running board using standard fenders/aprons/running boards?
    Any help greatly appreciated.
    Steve
  2. Never2old
    Never2old
    from so cal
    The running board brackets dictate ground clearance.
  3. catdad49
    catdad49
    Measured the coupe, 10" at the brackets and 10 1/2" at the rear.
  4. grumpy65
    grumpy65
    Thanks to you both.
    Am I right in ***uming that the front fender mounted to frame will dictate where the running board will sit as it attaches to the rear of the fender.
    @catdad49, are those measurements from the top of the splash apron where it mounts to the top of the frame down to the bottom of the running board? Seems like this would be a set dimension for standard setup.
    Steve
  5. Fomoco998
    Fomoco998
    The front fender will dictate where the running sits .
  6. catdad49
    catdad49
    Sorry Grump, measurement is from the top of the frame to the bottom of the running board bracket, 10" front, 10 1/2" rear.
  7. The running board mount is the dictator. It's fixed and stationary, the fender and board just join each other. neither are adjustable, in factory form that is. I'm ***uming your trying to mount things up without a stock frame or running board mounts.
    The Wizzard
  8. grumpy65
    grumpy65
    Thanks again for the info.
    Just trying to figure out if I can set my frame up lower to groung level and adjust apron/running board height for reasonable ground clearance. Guessing not as it all seems set by front fender, although anything is possible with huge modification and fabrication work. Not so keen on getting into that!!!
    Steve
