Technical Model A spring issues
Discussion in 'Traditional Hot Rods' started by sparky232, Aug 23, 2020.
  1. eldiablooxidado
    eldiablooxidado
    This is the current setup on an A sedan I just picked up. I'm guessing it's the same Speedway spring you just picked up. I'm gonna clearance the frame and run it how is for now and change it back eventually with the correct length reverse eye spring
  2. The Speedway unit
  3. 100% Matt
    100% Matt
    Speedway Spring = Made in China
    Old Yankee Spring= Made in the USA
    John Heckman, winduptoy and alanp561 like this.
  4. 100% Matt
    100% Matt
    Just did a short video about our Hot Rod Spring
    catdad49, rusty valley and sparky232 like this.
  5. sparky232
    sparky232
    Thanks man. I just can’t swing the $480, which is why I’m leaning toward the main leaf and adding few leftover from other springs
  6. dirt t
    dirt t
    Speedway sells Posie springs also
    -Brent- likes this.
  7. 100% Matt
    100% Matt
  8. sparky232
    sparky232
    Finally got my new spring yesterday, am I seeing things or does this not seem right? The slight arch along the spring is 2 inches different from side to side. IMG_7594.jpg IMG_7595.jpg IMG_7596.JPG IMG_7597.JPG [​IMG]
  9. dsiddons
    dsiddons
    from Indiana
    Is that a A rear spring? Has a hell of a arch. I thought you were gonna use a T rear spring setup? Anyway my T spring had a gap like that.
  10. sparky232
    sparky232
    I decided to go with a reverse eye A spring and will probably step frame as well. Was a little concerned about T spring hitting the 9 inch diff, probably overthinking.
    dsiddons likes this.
  11. -Brent-
    -Brent-
    @sparky232 that mis-fit is exactly why Posies won't sell the main leafs alone - even to swap into their own springs. I've even swapped used A main leafs with other stock A springs and had similar issues. However, in the few times I've pulled mains and had them reversed/rerolled (and trimmed #2 leaf) it's always worked well for me (and only cost me $30 and 15 minutes for the t*******).
  12. sparky232
    sparky232
    I don’t see it as a mis-fit, more of a mis- measurement. A 2 inch difference is quite a bit
    alanp561 likes this.
  13. sparky232
    sparky232
    Company I purchased from said it’s definitely not right and sending a new one once I return this one I’m guessing.
    After I waited nearly a month for it to be be delivered in the first place. Good thing I’m not in a hurry I guess
  14. 29Roadie
    29Roadie
    Ya that's not something I'd be very happy to see either. 2" out of alignment is a lot. It makes me think you should check to make sure your center hole is actually in the center too on the new spring.
    I've got a reversed Model A main leaf sitting here that I wasn't sure I was going to use. I've had it for a bit and I haven't even unwrapped it for some reason. Now I'm worried. You know what I'll be checking tomorrow first thing.
    I have a Model T spring in my roadster now and I'm just not happy with it. I'm going to go back to the A spring with the reversed eye and build a spring pack to dial in the something better.
  15. 100% Matt
    100% Matt
    That’s one of my springs.... out of 50 springs we had three that turned out to be misshapen. All our reverse eye mains are “small batch” and Made in the USA. Since covid hit our manufacturer’s turn around time has nearly tripled. Somehow the three misshapen springs got lost in the mix.
    We have a new one on the way too you. I apologize for the inconvenience.
    John Heckman and Happydaze like this.
  16. sparky232
    sparky232
    Replacement spring showed up.
    Same issue.
    I’ve decided to just get my money back at this rate.
