Technical Model A spring spred on '48 rear bones
Discussion in 'Traditional Hot Rods' started by anteek49, Oct 12, 2013.
  1. anteek49
    anteek49
    A fellow greybeard told me that in the day they used an A rear spring on a '48 rear to lower the A a bunch. Anyone ever see this? I'm altering a frame now that is getting a '48 rear but respect those springs. Pics would be better yet
  2. general gow
    general gow
    MODERATOR
    the thing about a later rear end is that the spring hangers are behind the axle. this does lower the back a bunch, but you have to lengthen the frame to get the rear crossmember back further.
  3. anteek49
    anteek49
    General,I'm using an AA frame and have about 15 inches more to play with than a car frame. Trying to figure out Zing the frame in the front to lower it without sacrificing foot or engine room.
  4. general gow
    general gow
    MODERATOR
    so you're talking about lowering the front? an A rear spring wouldn't do that at all...
  5. anteek49
    anteek49
    Lowering the rear with this and planning a Z to lower the front.two different operations
  6. Rehpotsirhcj
    Rehpotsirhcj
    I've heard of the T spring being used in an A frame (rear) to lower the ride height.
    I don't think anyone would have used an AA frame...aren't they heavy as hell?
  7. hotrod40coupe
    hotrod40coupe
    Using a '48 rear end will relocate the wheel in the fender and it will ruin the look of the truck. I'm not even sure the fender will fit with the wheel in the new location.
  8. edwardlloyd
    edwardlloyd
    from Germany
    It will if you move the rear crossmember 8" rearwards.
  9. 27troadster
    27troadster
    Let me see if I understand you correctly, you are using a '48 ford rear with the '48 radius rods which have the spring hangers behind the axle. You are going to install the rear cross member in a location that puts the wheel where you want it.
    If that is correct, then the '48 radius rods will lower the car about 6" or so.
    In addition to the lowering from the radius rods, are you asking if an A spring is shorter than a '48 spring?
    If you don't have a A spring I can jack my hot rod up and measure the unloaded height of the A spring. Its a speed way repop with the eyes the way Henry put them, it should be close to the factory spring. Let me know if this is the info you need.
    Of course removing leafs will lower the car. Moving the cross member up will lower it as well. Just make sure you have enough travel before the axle bottoms out on the frame. I'm running a stock A frame that I stretched but did not Z with '35 radius rods, spring behind the axle, with an A spring. I have about 4" between the axle and frame and it does bottom out if I hit large bumps too fast. Wish I would have z'd it.
    AA frames are cool, I got one for my A pickup project, they kinda look like a 32 but without the ridge, so it makes people scratch there head to figure out what the hell it is. Plenty heavy too, I do not intend to box mine. The gage and height are similar to a '70s pickup, I figure if one can put a big block in say a '70 Ford and beat the hell out of it running through the woods without frame twisting problems, then the AA frame should be just fine. Might add an x or k member though.
    Kipp
  10. 55willys
    55willys
    The spring perch centers on an A rear end is 49 1/2", 1937 rear is 48", and a T is 47 1/2". I am not sure about the 1946-48 rear as I don't have one to look at. The A spring is too wide to use on other axles but the T spring is only 1/2" narrow which is only a 1/4" per side. Jim (55willys)
  11. F-6Garagerat
    F-6Garagerat
    7 3/8"
  12. Equipped28
    Equipped28
    how far are the perch's out back on a 39 axle, i.e centre of perch to centre of axle?
  13. edwardlloyd
    edwardlloyd
    from Germany
    I move it 8" - it centers the wheel better in the wheel arch, but yes you're tectnically right.
    Ed
  14. sko_ford
    sko_ford
    The question in my mind is will a A spring stench to the hangers on the 48 rear? The v8 rears are wider
  15. Rehpotsirhcj
    Rehpotsirhcj
    mine also.
    I have an A rear crossmember (32 frame), and a 40 rear end. I'd like to use the A spring if possible. Not sure how well a 40 spring would work with the A crossmember.
  16. spooler41
    spooler41
    With the rear end set up in my '26 lakes modified, I used a '40 rear end, '35 rear bones,
    and a mod.A spring. I had no problem fitting the Mod. A spring to the stock '40 hangers, I did take out the 2 top leafs. I cut the spring mounts on the '35 bones and fabed new mounts to bolt them to the axle housing.
    .....................Jack
  17. Rehpotsirhcj
    Rehpotsirhcj
    Good to know Jack, thank you.
  18. Kevin Lee
    Kevin Lee
    Super Moderator
    I've used an A spring on a '48 rear end with no issues. (Shackles were at the correct angle as well)
  19. anteek49
    anteek49
    I went ahead today and put the '40 merc rear crossmember in the AA chassis. The drivehaft tube is about 2 feet too long. "40 Merc driveshaft is one piece with the pinion gear; are any others,besides model A's?
  20. Soviet
    Soviet
    Cut, shorten, sleeve, drill, pin, weld.
  21. anteek49
    anteek49
    Thank you,Soviet, so easy to do. maybe this thread can die now.
