Technical Model A Starter
Discussion in 'The Hokey Ass Message Board' started by theboss20, May 6, 2019.
  1. theboss20
    theboss20
    Got a Model A Starter that is somebody’s rebuild that won’t throw the drive out?? Don’t know what they did need some help
    Sent from my iPad using Tapatalk
  2. F&J
    F&J
    When you say the drive is not working, is the starter on the bench, or still bolted in?
    If it is still bolted in, and the motor spins but won't engage, it could be a broken Bendix spring on the drive. They can break if used with 12 volts, because the starter is much faster on 12v and that slams the spring too fast, meaning too violently.
  3. theboss20
    theboss20
    Starter is out and on the bench...it appears to be turning CW looking at the drive end of the starter...I think I should be a CCW starter if somebody can confirm that...the person that rebuilt the starter could have put the wrong armature in this starter??
  4. ejgloss
    ejgloss
    Model A is 6V Negative ground
  5. ejgloss
    ejgloss
    Not negative ground
  6. Rusty Karz
    Rusty Karz
    6 Volt positive ground if stock.
  7. theboss20
    theboss20
    Yes that’s’ correct
  8. Rusty Karz
    Rusty Karz
    If no one here can help go over to the Ford Barn Model A forum. Those guys live and breath Model A Fords.
    theboss20 likes this.
  9. F&J
    F&J
    That's correct. (The engine crankshaft turns clockwise when viewed from the front)
