Hot Rods model a starter
Discussion in 'The Hokey Ass Message Board' started by V4F, Nov 15, 2011.
  1. V4F
    V4F
    from middle ca.
    does anyone know who makes a starter kit to replace the foot starter button ??
    thanks .. steve
  2. pasadenahotrod
    pasadenahotrod
    from Texas
    Use an early Ford V8 starter solenoid and a starter button. Takes a mod to the starter or the stock A starter switch to mount cable directly to starter contact.
  3. V4F
    V4F
    from middle ca.
    thank you ......................... steve
  4. Bruce Lancaster
    Bruce Lancaster
    Also, you'll need to replace the copper contact lump with a stud...Drake's catalog shows 2 versions of V-8 stud reproduced.
    There useta was a kit for this that mounted a V8 solenoid on a special bracket right on the A starter...I think from memory mine is just set up to bear against that copper lump, but I would prefer a bolted connection to a cable.
  5. V4F
    V4F
    from middle ca.
    thanks . ill check them out .... steve
