Model A steel top?
Discussion in 'The Hokey Ass Message Board' started by cmichael, Feb 20, 2006.
  1. cmichael
    cmichael
    I have a 30' Model A Tudor Sedan I want to put a steel top on it. Does anyone have any suggestions on how or any pictures of similiar cars with this done?
  2. Major undertaking for a home project. Suggestions? Re-do it like Henry did it, then you have something to hook the new headliner to.
  3. 29 sedanman
    29 sedanman
    from Indy
    Here is my 29 Tudor with an 80 Oldsmobile wagon top skin.
  4. MikeRose
    MikeRose
    from Yuma, AZ
    Seems like theres some pictures of someone putting a steel top on a coupe in the new Rod and Custom. I don't remember how much of the work they actually show.
  5. pimpin paint
    pimpin paint
    from so cal
    Hey,
    Ya gotta choice of roof panels on a ceedan.......
    It'll depend on if ya like the look of ribbs, like the above pictured sedan,
    or the smooth look. Start lookin at mid sixties big Ford/Merc wagons for
    a roof clip, these will give ya a smooth look. Many of the ribbed paneled
    roofs from vans and full sized wagons will work, but not all have the crown
    you're after, without some work.
    When ya find the roof you like, buy the whole roof clip,this will leave ya
    plenty of material to work with. Cut and fit the panel very carefully, and
    weld it in in with small tack welds diagonally across from one another.
    Roofs won't take much **** off ya, from welding heat, before they'll up
    and warp on ya. Go slow, it shouldn't take alotta pink metal to make it
    purdy.
    S****ey Devils C.C.
  6. man-a-fre
    man-a-fre
    chevy astro van works slick.
  7. cmichael
    cmichael
    Thanks for the advise! I hadn't though about using a donor top!
    Thanks
