Hot Rods Model a stone guard.
Discussion in 'The Hokey Ass Message Board' started by dalesnyder, May 5, 2023.
  1. dalesnyder
    dalesnyder
    I would like to cut a stone guard for a 31 ford so that it fits behind the stock 31 shell.
    Is this possible or will the wire weave just fall apart?
    Also does anyone know of a source for wire mesh that would have the same appearance as a stone guard.?
    Thanks
  2. lostone
    lostone
    from kansas
    You can buy all kinds of stainless wire mesh in about any size squares on ebay.
    Been looking at it myself, thinking about building a grille for my 31'.
  3. I did it on the cut down 32 commercial shell I used on my old touring. Have another on the wall for just the same reason. You will be fine
  4. woodiewagon46
    woodiewagon46
    from New York
    McMaster-Carr has about any type mesh you could want.
    05snopro440 and lowrd like this.
  5. 1946caddy
    1946caddy
    from washington
  6. acme30
    acme30
    from Australia
    I used black powder coated stainless steel security mesh for mine. It is the stuff they use to make security doors and security screens.
    If you buy it new it is quite expensive but if you have recyclers near you I picked up a second hand security door for $20 and then cut the mesh out of it.
    It is screen is tough as and my coupe as done nearly 80,000 miles with this on it. It still looks good, has not affected cooling and has definitely saved my radiator from stone damage more than once.
  7. the violator
    the violator
    I cut the mesh out of my stone guard and epoxied it to the inside of the grille on my 29 RPU. The mesh stayed together. Not sure if I am going to keep it like that forever but it certainly is saving the radiator from damage.
    Tim likes this.
  8. denis4x4
    denis4x4
    from Colorado
    This was made from stainless shaker screen and mounts outside the grill shell.
