Technical Model A subframe rear crossmember?
Discussion in 'The Hokey Ass Message Board' started by Aaron D., Aug 24, 2020.
  1. Aaron D.
    Aaron D.
    I bought a subframe rear crossmember thinking it was for a Coupe/ Roadster, but when I hold it up to my Coupe the inside mounting brackets are narrower. Is this for a Tudor Sedan? The outside to outside measurements of the inside mounting tabs are 34-3/16”
    Thanks
  2. fiftyv8
    fiftyv8
    from CO & WA
    From what I know, yes it is probably for a Tudor if wider.
    Could possibly be narrowed, but you will probably find there is a Tudor guy out there with a roadster subframe cross member looking for a swap...
  3. lostone
    lostone
    from kansas
    Yeah I missed a cheap tudor one on eBay 2 weeks ago...
  4. Aaron D.
    Aaron D.
    The mounting tabs in the picture are narrower than the one in my Coupe. Does someone have the measurements for the Tudor sedan so I can verify that the one in the picture is indeed for the Tudor?
    Thanks
  5. lostone
    lostone
    from kansas
    Bump...... For ya, surely someone can post what heads to run on a Brand new vortec crate motor and get a 100 replies surely someone has crossmember to measure off of....
    Aaron D. likes this.
