Model A suicide front end question...
Discussion in 'The Hokey Ass Message Board' started by Mizlplix, Jan 14, 2007.
  1. Mizlplix
    Mizlplix
    from S/W USA
    Having no experience with a spring-behind-the-axle set up, I question the strength.
    The model A wishbone was not designed to take twisting/and downward shearing forces. They seem to be fairly thinly built.
    Is it necessary to reinforce it to be safe?
    Do they break a lot?
    This is where all of your experience will really pay off for me. THX, DB
  2. Crusty Nut
    Crusty Nut
    try the search feature. This is a dead horse.
  3. Mizlplix
    Mizlplix
    from S/W USA
    "Search feature" already used to a silly extent. So many conflicting answers exist with a database this large.
    My thanks to you, sir for at least taking the time to respond. DB
  4. Model A axles are not normal candidates for spring behind because it isn't necessary. Spring behind is usually reserved for the axles that originally had the spring in front. i.e. a '39.
    Spring behind is not what defines a suicide front end. A suicide front end has the spring perched out in front of the crossmember, and can be configured spring over or spring behind.
    There are a lot of HAMB threads that discuss it. Your concerns about wishbone strength have been addressed quite a few times here, and opinions differ. I use Google vs HAMB search to get more specific results. Try this list of threads..........
    http://www.google.com/search?sourceid=navclient&ie=UTF-8&rls=GGLG,GGLG:2006-42,GGLG:en&q=%22spring+behind%22+site:www%2ejalopyjournal%2ecom
  5. 30roadster
    30roadster
  6. 30roadster
    30roadster
    and here an awsome fabrication from Paul
  7. Paul
    Paul
    Editor
  8. 30roadster
    30roadster
    I did goof...you got the right one....but they are both great work :)
  9. Paul
    Paul
    Editor
    even then, the second example isn't really a suicide front end,
    it's a spring behind with spring in the stock location but axle in front and still under the frame.
  10. Frank
    Frank
    ...and/or having your spindles flipped around with your tie-rod out front becoming your bumper. Not to mention Ackerman geometry that can never quite get perfect due to the way the spindles are flipped around.
