Hello fellas, I was wondering if the tail gate of a 1926/27 Model T pickup is the same dimensions "size, height and width" as the Model A tail gate, say a '28-'31? Mine is a bit warped and beat up, so i'm looking for one in better condition for my pickup and a T one seems harder to find these days. thanks for your help, cab
I did a search and found nothing, so back to the top, someone has to know this, Please point me in the correct direction, thank you guys!
I have a 28-29 tail gate i can measure for you this evening, however i dont have any info on a T tail gate. Lmk if it is the A dimensions you need. Leon
I can't help with the dimensions but there is a place in Kansas called Model T Haven. You might try them for a T gate.
Thanks Guys! I was able to drive down to ALL FORD in Campbell, they made a call and found out The T tailgate is the same dimension as a Model A and will work with it, so that's good to know and will be easier to find! I also took the time and called Model T Haven as you suggested and they told me the same thing except for a very slight difference on the hinge that loops around the bottom of the tail gate, which you can barely tell thanks for taking the time to respond. cheers, cab
