Hot Rods MODEL A TCI Chassis Header suggestions?
Discussion in 'The Hokey Ass Message Board' started by GBRG07, Dec 31, 2015.
  1. GBRG07
    GBRG07
    Have a Model A SBC looking at block hugger header suggestions ?
    Pretty limited space on left side with steering shaft there. What has worked for you guys.
    Thanks Gord
  2. cpd682
    cpd682
    from DFW, Texas
    Take a look at Sanderson Headers. I recently got a set for my 32 with a Chevy crate engine. They hug the block just enough to clear the steering and the narrow frame.
    They were great people to deal with and are also an alliance vendor.
  3. Firecat7
    Firecat7
    SANDERSON HEADERS ...**** , big time.... the flanges don't clear the spark plugs to get a socket on them....they suggest some sort of expensive shorty plug...instead of correcting their improperly designed flange . You sure a "normal bock hugger (patriot) won't work?... hedman has that flat design aswell. Raw sandersons may work , so you can cut ,grind modify for plug clearance. Good luck
  4. Texas Webb
    Texas Webb
    Also check Red's.I hear good things about them.
  5. hotroddon
    hotroddon
    Patriot Block huggers should work perfect for you
  6. GBRG07
    GBRG07
  7. GBRG07
    GBRG07
    Were those Sanderson centre exit like Ramhorns ex manifolds?
  8. Firecat7
    Firecat7
    Sanderson used to make a good set... "c3's" full length , more performance header.......the old ones were fine, I suspect new c3 header uses same flange as their blockhugger. PLUG PROBLEM... Beware
  9. bjinx
    bjinx
    How about some pics of your car?
  10. GBRG07
    GBRG07
  11. GBRG07
    GBRG07
    The car was my Fathers, he p***ed a few months back.
    I am thinking of the inside the frame headers to clean up the look and give options for putting full fenders back on or hood with skirts.
  12. alchemy
    alchemy
    Wow, that's gonna be a tight fit. I think you will need to modify that steering no matter what brand headers you choose.
  13. GBRG07
    GBRG07
    I am thinking that as well.
    Might just be easier to buy header I want and just re do steering shaft to fit them.
  14. bjinx
    bjinx
    I have the same TCI Ch***is with same style front suspension and am using Chevy Ram Horn turn back style exhaust manifolds.
    P***enger side, '68 - '72 Chevy 1/2 ton pickup
    Driver side exhaust, '70's chevy car I believe Nova
    You can snake the exhaust around the steering shaft, I am using a chevy '71-'72 van column which has more shaft at the end of the column which puts the end of the shaft lower. I do not have pics but worked all this out when I was figuring out the length of my steering column mount. You might have to move your alternator to the top of the engine though. Hope this helps also my car will have fenders.
  15. Hot Rods Ta Hell
    Hot Rods Ta Hell
    My condolences re. your Dad.
    TCI used to sell a stage V ch***is complete with SBC, headers, etc installed.
    Since it's a TCI ch***is (their engine and steering mounts), you may want to contact them/send pics to see what application they use for headers and if they think it will work with your column location.
  16. FinnishFireball
    FinnishFireball
    My SBC / A stock frame setup cleared barely with blockhuggers. It's hard to tell by pics but you may or may not just survive. I have had two separate sets, steel and stainless in pic, and both sit similar in the hole. I have no clue of the manufacturer of either of them.
