Technical Model A tilt out windshield
Discussion in 'Traditional Hot Rods' started by Mike Colemire, Jun 22, 2019.
  1. Mike Colemire
    Mike Colemire
    Has anyone got a pic of how the tilt out arms go together? I bought a alum frame and purchased the tilt out arms separate, didn't think it'd be a big deal but apparently it is. My arms have the notches in them and one thing that confuses me is the knobs are threaded all the way through. I've searched the internet but keep coming up with ATV windshields and model A wipers. I know it has to be simple and I'm just not seeing it.
  2. HotRodTodds
    HotRodTodds
    If nobody responds before, I can send a picture tomorrow
  3. upspirate
    upspirate
    In the mean time, post a pic of what you have....
  4. Mike Colemire
    Mike Colemire
    I didn't take a pic, just thought of that when I decided to post. I'm putting in the door gl*** after church tomorrow so I'll get a pic then and post it tomorrow evening. Hot rod todd, whenever you can post a pic I'd be grateful, thanks. This all came in a kit and since it's been awhile I don't remember where it came from, hope it wasn't from Howell's, I tried some of their patch panels and wasn't to happy with them.
    upspirate likes this.
  5. kadillackid
    kadillackid
    Does this help ??
  6. sloppy jalopies
    sloppy jalopies
    The round screw hole goes upward and also away from the driver...
    the pivot brackets on the frame are different ['28-'29 and '30-'31]... left to right...
    upper w/s hinges are also different...
    there is a 5/16" threaded stud that comes out of the A pillar... the slot on the swing arms slides over them... the knobs thread onto the studs, pinching the swing arms... rubber gasket and a cupped washer go between the arms and knobs...
    pic of A pillar studs and the knobs...
    beware the model T, looks like the A but is 1" narrower... you can spot them cause they have a tube welded on for the manual windshield wiper arm... snake bitt 1 004.JPG
    osage orange likes this.
  7. Vic Walter
    Vic Walter
    Here is what mine look like. I have no way of knowing if they are correct. I have had them apart a couple of times and this is the only way they go together and still function like I guess they are supposed to.
  8. Mike Colemire
    Mike Colemire
    This is a pic of what I got, forgot to take a pic of the part on the windshield frame.
  9. Mike Colemire
    Mike Colemire
    Also, the covers for the windshield post have a hole in them, no stud or anything just a hole.
    poprivit likes this.
  10. flatford39
    flatford39
    That didn't come from Henry that's for sure. Where did you get them??
  11. Mike Colemire
    Mike Colemire
    Don't remember where I got them, should have bought them from Mike's A fordable parts, everything I got from him has been ok.
  12. RB35
    RB35
    Your brackets are an after market accessory. Extra notches so they won't slip. If you go to Bratton's website (they also offer them) you'll find a picture showing the washers, etc. On mine from the A-pillar post out they go:
    steel flat washer, bracket (as shown above), rubber washer, cup washer and knob.
  13. RB35
    RB35
    And the little screws attach the bracket to the w/s frame.
  14. I’ve not seen the arms with the slots but they look like they would lock the window position very positively.
  15. RB35
    RB35
    I guess in the old days of low speed A's, w/s slippage wasn't an issue. Mine hasn't closed at speed yet, but I've only had it up to 80. If I'd seen the multiple notch in the catalog first...
  16. Mike Colemire
    Mike Colemire
    There is nothing on my A pillars, there is a hole for a stud I presume in the windshield post garnish molding. I'd say they eliminated them on the chop. I'll have to come up with something on that.
  17. HotRodTodds
    HotRodTodds
    Does this help?
  18. Mike Colemire
    Mike Colemire
    You all have been a lot of help.
  19. HotRodTodds
    HotRodTodds
    Just take a bolt that fits your hardware, cut or grind head off and weld it into post. It would help to have a second set of hands to hold the bracket in place and make sure it will operate in and out before you drill and weld it.
  20. sloppy jalopies
    sloppy jalopies
    memory says that half of the studs are flattened …. they rivet to the A pillar... snyders has them...
  21. Mike Colemire
    Mike Colemire
    There is 2 plates in the post where the screws go in to hold the garnish molding. I can make a piece to connect them and mount the stud to it. I have to drill and rethread holes to mount the moidings anyway.
  22. Here's my '28:
  23. 2NDCHANCE
    2NDCHANCE
    The notches on your aftermarket arms are a great feature. I have had my window slam shut at highway speed and it will wake you up for sure.. Gary
  24. Mike Colemire
    Mike Colemire
    Thanks oldtimer, the notches are why I bought these, that I remember. Where I bought them at is a mystery. My memory ****s anymore.
  25. 53OlderThanMe
    53OlderThanMe
  26. sloppy jalopies
    sloppy jalopies
    Genes12320 likes this.
