Here is most of everything you need to put a T5 behind your Model A banger motor. This adapter kit uses a Model AA bellhousing with your passenger stock pedals in the correct location. Included is the following: - Adapter plate with pedal rod - Bearing retainer collar to use the stock AA or 40 ford release bearing - Pilot bearing - Short throw shifter spacer - '86 mechanical speedometer T5 - all of the hardware you need. I also have a 3.7 1st gear ratio s-10 T5 that I could swap tail shafts with if you would rather have that. I make these adapters along with multiple others, so I usually have plenty available if you just need the adapter. I was keeping this trans for my own project but I decided to keep the torque tube and am working on making a T5 4x4 to torque tube adapter as well as making the RTS F150 conversion. I have no problem shipping this stuff, but it will be between $100 an $200. I am open to trades as well. I am looking for anything old and neat but particularly, a 30/31 Model A truck cab and/or a soft serve ice cream machine....
