model a total weight?
Discussion in 'The Hokey Ass Message Board' started by odins701, Sep 23, 2009.
  1. odins701
    odins701
    does any one have an idea what 1930 tudor sedan weigh?
  2. Mazooma1
    Mazooma1
    my '30 panel delivery with a sbc weighed 2550
  3. odins701
    odins701
    really? that just seems like alot.
  4. pasadenahotrod
    pasadenahotrod
    from Texas
    One and a quarter tons is a lot?
    My Old T Roadster weighs 1750 pounds, 2550 is not a lot!
  5. Mazooma1
    Mazooma1
    the '34 in my avatar with a sbf is 3100#....all steel
  6. odins701
    odins701
    mines all steel too. so around 2550 it is. thanks guys!
  7. pitman
    pitman
    I think you'll find his weight to be a good approximation.
    My full fendered '31 coupe w/ 2" x 4" tube frame 3/16th wall (so heavy)
    weighted 2700# w/an SBC and a Muncie alum case trans.
    The roadster, with an eye on the scale during building, open wheeled
    no cast iron, AL 4 banger, AL vette rear and mostly open '32 rails is <1500+ lbs.
    With luck, anywhere in the neighborhood of 2600# is reasonable.
  8. Craig Owens
    Craig Owens
    My Model A fenderless coupe weighed in at 2480 on a certified scale. That was with a full (16 gallon) tank of gas, but before I added some sound deadener, aluminum interior panels, and an aluminum hood. I'd say it's at 2550 now.
    Craig
  9. HotRodBen1987
    HotRodBen1987
    My 1931 tudor sedan (all steel) full fendered, SBC/TH350 weighed 3100 full of fluids and with me in it.
  10. alleyoop392
    alleyoop392
    I was surprised to find out my altered in my avatar was 2006#s with me in it after a pass. That's a cast iron headed 392 that is full of hardblock. I go in at 180#
    It adds up.....................
  11. 30panel
    30panel
    My 30 Panel on cert. scale, Pontiac and a heavy 4 speed hydro 17 gals fuel 127 Lbs, no driver 3060 lbs.
  12. pan-dragger
    pan-dragger
    i'd figure somewhere between 2500-2800 lbs.
  13. unkledaddy
    unkledaddy
    My fenderless '30 A Tudor (3" chop, filled roof, steel innerstructure, steel floor, SBC, TH350, Ford 9", no interior just bench seat, 17 gal fuel cell 1/2 full, with me and the wife) weighed in at 2760 lbs (1460 lbs front and 1300 lbs rear), on a certified truck scale.
  14. Von Rigg Fink
    Von Rigg Fink
    from Garage
    well i woulda figured it would come in around 2600 to 2800..
  15. My roadster pickup (avatar) has a steel cab and steel box with glass fenders and a small block Chev/turbo 350---It weighs in at 3100 pounds on a certified scale.
  16. millersgarage
    millersgarage
    highboy 28 coupe, no air sbf auto, 2320lbs at Louisville UPS scales
  17. HATED1
    HATED1
    my 31 rpu weighed 2250lbs with 2 people in it. 1 being a large dude and i so it was actually around 1900 lbs with a full stock tank and a sbc.
  18. Brewton
    Brewton
    My Model A Coupe weighs in at 2430 lbs without my big ass in it.
  19. Zookeeper
    Zookeeper
    Wow, that's a lot. My '30 closed cab pickup with 'glass fenders/steel cab and bed, a SFB and toploader weighed 2740. How does yours weigh nearly 400 lbs more with similar stuff and no roof?
  20. Zookeeper--I really have no answer to that. My frame is an original A frame, boxed full length. The rearend is a 1988 S10. The box on mine is made of a much thicker steel, #14 ga., and the valances below the box are made from #12 ga. steel, but I doubt that can explain away 400 pounds. My rear fender spacers are made from 1" square tube with a 1/8" wall, and since I had to pretty well eliminate the subrails when I shortened the sedan body to make my pick-up cab, I used a peice of 3/16" steel plate as the "floor" and built the body up around it. I guess its just that a lot of little "extras" add up.---Brian
  21. so Fink, how much if ya take out all the beer cans hahahahha
  22. I don't have my Ford book right in front of me but I think it says the shipping weight stock is around 2800 lbs give or take.
  23. Zookeeper
    Zookeeper
    It sure is a great looking truck, any other pics?
  24. Von Rigg Fink
    Von Rigg Fink
    from Garage
    enough to melt down and make a manifold out of?:D
    the same ones you brought over;)
  25. Thirtycoup
    Thirtycoup
    My '30 model A coupe in my avitar with 12 gallons of gas, 350 sbc and 700R4 tipped the scales at 2360.
  26. Zookeeper--
  27. Zookeeper
    Zookeeper
    Perfect stance, perfect color, that is one nice truck from any angle.
  28. pecker head
    pecker head
    My 28 sedan 2480 full interior , my 28 coop 2228 not much interior !
