model A tranny and exhaust question
Discussion in 'The Hokey Ass Message Board' started by hillbilly4008, Nov 26, 2010.
  1. hillbilly4008
    hillbilly4008
    from Rome NY
    Hi there, Ive got this engine from a '30 model A. Can somebody tell my why the exhaust manifold looks like this and not like the typical "tube" style ive seen on others
    Also, pulled this tranny out of a '31 5window coupe. Whats the lever on the shifter? Is this a truck tranny with PTO?
  2. Rex_A_Lott
    Rex_A_Lott
    The manifold is made that way to make the heater work better. It was essentially a sheet metal funnel around that manifold and let air from the fan blow through the firewall when a little door was opened.
  3. JohnEvans
    JohnEvans
    from Phoenix AZ
    Yep a 4 speed truck trans. Good for a truck or oneway boat anchor.
  4. jetmek
    jetmek
    the lever allows you to shift into reverse. is that a hole on the top of the bellhousing?
  5. hillbilly4008
    hillbilly4008
    from Rome NY
    Yeah, there is a chunk missing. I doubt i'm going to use this thing.
  6. modelAsteve
    modelAsteve
    Ford made a special rear bearing retainer and u-joint to put the AA 4 speed trans a passenger car or pu. Looks like you might have them. Allows you to use the car rear end and not shorten the drive shaft. Must also use the AA bell housing. I have this set up in a '30 pu.
  7. BCCHOPIT
    BCCHOPIT
    That sucks... the AA bell housing is a key part to putting a T5 behind that banger
    Good eye Al:D
