Model A trans seperation issue HELP
Discussion in 'The Hokey Ass Message Board' started by flatheadz-forever, Jun 13, 2013.
  1. flatheadz-forever
    flatheadz-forever
    from new jersey
    Okay so have the engine out of my model a ch***is and the trans has all the bolts out and is dis connected almost completely, I have the collar off and it is being supported by an engine hoist and I cannot get the trans separated from the torque tube... am I missing something any suggesstions... I sprayed it down today with wd-40... still had no luck
  2. Is it an early 28 with the multi disc clutch?
  3. flatheadz-forever
    flatheadz-forever
    from new jersey
    no its a 1930 I have the engine and trans seperated I just can seperate the ****** in the ch***is from the torque tube
  4. 325w
    325w
    The u joint must be stuck . The pedals come with trans don't they?
  5. Hotrodmyk
    Hotrodmyk
    Has to be the u jount stuck. Yes pedals come out with trans.
  6. Mooseandsqurl53
    Mooseandsqurl53
    from N.J.
    Also, check that the trans is not stuck in the frame adding to your problem. I have read where you actually need to spread the frame just a smidge to get the rear mounts to go between the ears on the frame. I'm ***uming the bell housing if still on the trans. I read this in one of the Model A restoration books I had. If this isn't the case, look for any little gap you can find back there and start spraying the hell out of it for a couple of days.
  7. flatheadz-forever
    flatheadz-forever
    from new jersey
    yeah the trans is being supported by a cherry picker because the only thing its attached to is the torque tube
