Technical Model A Tudor Sedan to a Sedan Delivery Conversion?
Discussion in 'Traditional Hot Rods' started by txoldrodder, Oct 26, 2016.
  1. 2NDCHANCE
    2NDCHANCE
    When cutting the door we looked at many pictures on the internet as we could find. Then after much discussion, we measured and winged it. Air cutting wheel, and a bosch industrial jig saw, and a good tape job.
  2. txoldrodder
    txoldrodder
    After making cardboard templates what did you use to make the framing for the body and door?
  3. 2NDCHANCE
    2NDCHANCE
    My fabricator friend (Davey Scheimann Jr.) had some metal bent up just for the job. I can't remember the gauge thickness. In all I think we used about three different thicknesses. Then we spent lots of time making carboard templates, and we gave the jig saw a good workout. The inner and outer jams are pretty substantial. I'll check on the metal gauges. Gary
  4. txoldrodder
    txoldrodder
    What did you put behind the hinge area for extra support?
  5. 40Standard
    40Standard
    from Indy
    cool idea. I would use the gl*** side windows
  6. gas & guns
    gas & guns
    That is some bad *** work right there!
    Slowrln likes this.
  7. SCtattooer
    SCtattooer
    Bringing this back up to the top. If you're still looking to do this, I have a new unused Gibbons kit and a decent body to work with.
  8. Hombre
    Hombre
    All Model A's share a common wheel base Coupe's, Two Door Sedans and Four Door Sedans all have the same 103 1/2" wheelbase. I would be greatly surprised if Ford made the Sedan Delivery any different.
  9. 2NDCHANCE
    2NDCHANCE
    IMG_0954.PNG IMG_0954.PNG Here is another picture for this thread.
  10. 2NDCHANCE
    2NDCHANCE
    Sorry about the double picture.
  11. gimpyshotrods
    gimpyshotrods
    No need to apologize. I could look at that thing for days....
  12. Hombre
    Hombre
    I could not agree more with gimpy about the apology. No Model A guy would ever tire of looking at those pictures ever.
    duecesteve likes this.
  13. Chainsaw chipper
    Chainsaw chipper
    from Illinois
    The wheel base is the same as stated but the sighn panel on a delivery is longer than the window opening on a tudor sedan body.That maybe why they look longer,It's in the upper 1/4 panel.I did one 30 years ago and used tudor sedan lower 1/4's and real sedan delivery uppers .everything fit and went together without a problem.1928's were bolted together ant the belt line and 29's were spot welded.Ford made ruffly 2,000 of the 28/29 sedan delivery's.
  14. Tim
    Tim
    from KCMO
    Man the over lap is a nice detail but dang that door sill sold me what a cool car!
  15. manyolcars
    manyolcars
    A guy here has a sedan with back door cut out. Then they sliced it horizontally. Both halves of the door open like a station wagon
  16. hotrod-kustom
    hotrod-kustom
    I be glad when i did see it .... i have just do same work with my 1930 Tudor. i was finnished but i did feel I WANT A Delivery not a tudor.
  17. hotrod-kustom
    hotrod-kustom
    hotrodjack33 and duecesteve like this.
  18. hotrodjack33
    hotrodjack33
    I built this one about 15 tears ago, but started with a '31 Slantwindow Fordor which gave me a shorter front door and longer side panels. Did all my rear door jamb/frame almost exactly like @2NDCHANCE .
  19. vanherrb
    vanherrb
