Model A Tudor windshield
Discussion in 'The Hokey Ass Message Board' started by 29 sedanman, May 3, 2005.
  1. 29 sedanman
    29 sedanman
    from Indy
    I need to get a windshield for my 29 Tudor. I need to know if the 28-29 and 30-31 windshields are interchangeable. If not, how do you tell them apart? Also, has any one ever used one of the repopped aluminum ones from Mac's? I will need to cut 4" out of the winshield when I get it. I am ***uming that I can simply cut the upright side post, re-miter the tops, and drill for the screw to attach the top rail back in. If this is the wrong way to go about this please let me know. If any one has a windshield they need to get rid of let me know.
    Thanks,
    Tracy
  2. Boones
    Boones
    from Kent, Wa
    I believe they are the same
  3. Crestliner
    Crestliner
    Being 30-31 is about 1 1/2 " wider I doubt they are the same. If you can measure the opening there is a chance I have one. I can even bring it to Indy the 20th.
  4. ResedaCoupe
    ResedaCoupe
    from Benson, VT
    I believe the frame is the same. The hinge (that mounts to the roof header) is different.
    I used a Polished Speedway frame, and it worked. Polish was good, but the outer area on the lower corners had to be worked in by my gl*** guy.
    I wanted to chrome an original, but the shop was hesitant to drop hollow 75 year old tin in to the tank.
    Hope it helps
  5. they are basically all the same for closed cars , except there are two heights...14-3/8" and 16"...your tudor will need the taller one.
    the difference is in the upper hinge and in the little brackets on the sides that the windshield sliders attach to
  6. Here in Finland they chromed original windshield of my -28 A with no problems. Actually it was quite a good, looks fine from far but you can see erosion spots near. I don´t worry, my pick up will not be a show car.
    Does somebody know the size of gl***? I didn´t have gl*** at all when I bought the windshield. It would be much easier to make a model if I knew the measurements.
  7. 29 sedanman
    29 sedanman
    from Indy
    I will measure it tonight and let you know tomorrow. Are you coming to the swap on the 20th? I will be there on the 21st. My dad sets up there for all of the meets but I cannot get off of work to go on the 20th. I will be there all day on the 21st. If you have one I could meet you some where. I'm still trying to get at least a half day to go out on Friday.
  8. 29 sedanman
    29 sedanman
    from Indy
    I measured the windshield opening on my car this morning. These measurments are the front edge of the opening. The top is 44 7/8". The bottom is 44". The sides are 11 1/2". The middle is 9 1/2". Let me know what you have got or e-mail me a picture. tracy_turner@praxair.com.
  9. BillyB
    BillyB
    Tracy
    If ya end up needing the hinge part that mounts to the header, let me know. I have an extra you can have for shipping costs if ya need it.
    Bill
  10. i just measured the windshield in a `29 tudor , the width at the top is 45-1/2" , the bottom is 44-3/8"....and is 16" high at the outside
  11. 29 sedanman
    29 sedanman
    from Indy
    Thanks for the offer. I will keep you in mind incase I find a windshield with no hinge.
    Thanks again,
    Tracy
  12. Crestliner
    Crestliner
    I have a few windshield frames.
    1- 30-31 Top 44 1/4 bottom 42 1/2 sides 14 3/4 center 12 3/4
    2- 28-29 ? " 43 1/2 " 42 " 14 " 11 1/4
    3 ? " 43 1/2 " 42 3/8 " 15 1/2 " 12 3/4
    These are frame sizes, if you use a gasket it will be about 3/8 to 1/2 on each side.
  13. 29 sedanman
    29 sedanman
    from Indy
    What kind of shape are the 28-29 frames in? Is there a hinge? I am sending you a PM with my number.
