Technical Model A -V8 Full Fender
Discussion in 'Traditional Hot Rods' started by Chop50, May 7, 2023.
  1. Chop50
    Chop50
    Hi All,
    Has anyone built a full fender 30/31 A-V8 with 32 K member and 34 wishbone? Have seen them as highboy but how about with full fenders..
    Thanks, Steve
  2. j ripper
    j ripper
    from napa ca.
    Yep!
    Fake k member, no k
    33-34 wishbone modified with Model A ball yoke.
    rusty_bits, LSGUN, rod1 and 22 others like this.
  3. junkman8888
    junkman8888
    j ripper, outstanding work.
    Atwater Mike likes this.
  4. banjorear
    banjorear
    Agreed. Car looks killer!
  5. j ripper
    j ripper
    from napa ca.
    Thanks fellas! I’ll share more details in a bit if anyone has interest:)
    SS327 likes this.
  6. banjorear
    banjorear
    100%. Please do.
    05snopro440 likes this.
  7. j ripper
    j ripper
    from napa ca.
    Here’s where it started. Early 1930 Standard Roadster. Garaged and untouched since 1997. I got it home and literally put a battery and fuel to it and it fired right up and ran as it should.
  8. j ripper
    j ripper
    from napa ca.
    After everything checked out and confirming that the vehicle would operate. I replaced the oils and gave it a simple lowering job. 33-36 axle. 32-34 spindles. 32 spring perch pins w/ 1/4” spacer. Reverse eye main leaf for the front. Rear was a reverse eye main leaf with a few leaves removed. 5.50 and 700 for tires.
  9. Chop50
    Chop50
    Beautiful work. Were you able to get exhaust inside of the frame rails, what steering did you use?
    Steve
  10. j ripper
    j ripper
    from napa ca.
    Thank you! Yes exhaust fits between frame rails then exits under the running boards. 1.750 straight out. The steering is F1. I’ll post all the details soon.
  11. Hoping to do something similar- so I will subscribe, thanks in advance.
  12. j ripper
    j ripper
    from napa ca.
    F5D7B55F-5389-4D25-B672-82C7D7F260E3.jpeg Here are the details. Sorry to hijack your thread chop50. Haha
    Ch***is:
    Model A frame. Stepped, lengthened and narrowed/pinched in the rear to accept spring behind axle and fit in between sub rails and under rumble seat base. Wheelbase has been shortened .875”.
    Unaltered model A front crossmember
    Reproduction K member.
    Flat buggy spring rear crossmember.
    33-36 front axle heavy drop from Greg (Anson).
    32-34 spindles.
    33-34/model A wishbone.
    Reverse eye spring.
    Model A spring perches.
    Model A tie rod (above wishbone)
    Model A drag link modified to be adjustable.
    Model A shocks.
    Reverse eye 40 ish spring in rear.
    F1 steering box. (Flange relocated)
    40 ish brakes.
    Drivetrain:
    59A. .100 over. 4”. Weber F1.
    3 speed box.
    1938 3.54 rear axle
    Wheels/tires:
    K/H. 7.00 rear. 450/475 front.
  13. banjorear
    banjorear
    Love it, man. Awesome car that sits and looks right. Seeing this makes me regret selling the fenders to my '28 roadster.
  14. Model A Gomez
    Model A Gomez
    Full fender V8 Sport Coupe and my avatar was also a full fender V8 A both with flatheads.
    hfh, guthriesmith, 282doorUK and 2 others like this.
  15. j ripper
    j ripper
    from napa ca.
    Thanks man!
  16. Dedsoto
    Dedsoto
    from Australia
    Any ch***is shots J? would love to see the step & extension, I'm currently dreaming up the V8 ch***is for my roadster
  17. j ripper
    j ripper
    from napa ca.
    IMG_3569.jpeg 64461164879__A626E509-6547-4EA2-891E-21F3A6FECD86.jpeg IMG_3390.jpeg IMG_3339.jpeg
    Hope these help.
    LSGUN, JalopyJimbo, Hotrodmyk and 5 others like this.
  18. Chop50
    Chop50
    J,
    That is quite beautiful, thanks for sharing. I have a 30 coupe that I have been thinking of upgrading to AV8 for a little more get up and go.
    Steve
  19. j ripper
    j ripper
    from napa ca.
    Thank you, Steve! The V8 will make a huge difference.
  20. redoxide
    redoxide
    not 30 /31 . but a fendered AV8
    original frame with repro 32 K model A rear axle , 37 trans, 21 stud flat head from WW2 era Bren gun Carrier
    dropped I beam, tele shox and stock front spring.
    19 incj A wires and BFG Silvertown ww
    built cheep from what was laying around, wheels and tyres came off my old 30 coupe . tyres are older but like new tread wise and barely seen sunlight so pressed them into action
    chopped screen posts and screen .. not much else to say about it really .. other than I need to finish it :)
  21. Chop50
    Chop50
    Nice! I had a 29 Highboy back in the early 70's. Wish I hadn't sold it. Got married, moved away. Back at it in full force.
  22. Sart156
    Sart156
  23. wheeltramp brian
    wheeltramp brian
    Does that black one above have 18s in the back? Looks great!
    Outback likes this.
  24. Chop50
    Chop50
    Hi,
    Did I see your car at Vintage Drags, Oxford Maine Memorial Day weekend?
    Steve
  25. Sart156
    Sart156
    Ya that's the one! Really looking forward to the next nevd!
  26. Outback
    Outback
    from NE Vic, Oz
    Those wheels fill up the guards nicely! I'm curious too, I have a pair waiting to be pressed into service.
    guthriesmith likes this.
  27. 282doorUK
    282doorUK
    Those A wires do look good how you have them fitting the wheel arch, if I could get mine like that it would be cheaper than me looking for straight 35s. What size tyres are they and how have you lowered the rear?
  28. I run A wires on my T Coupe. 4.50 x 19 Blockley front, 6.00 x 16 Michelen DR rear.
    Outback likes this.
  29. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Great thread Thank You Chop50 And all who pitched in.
    This is the kind of stuff I have hoarded for years.
    Sorry to be that guy,,, but sorrow is what causes me to ask,, not to press action too hard .
    Been there done that. 33 years . My back still hurts and the car was a loss ( big loss )
    Outback likes this.
