model A vin #
Discussion in 'The Hokey Ass Message Board' started by Slag Kustom, Feb 22, 2006.
  1. Slag Kustom
    Slag Kustom
    I need to know how the stock numbers where stamped in?
    where there stars at the ends of the numbers like some other cars have?
    was there a dash between the letter and numbers ex A-3378568
    the numbers in my frame have too much rust pitting and cant get a good rubbing of them to get the tittle for it
  2. glassguy
    glassguy
    slag. you can just make one up for a model a, theres no record of their vin numbers due to a fire in the 50s or 60s most people just use the #s from the motor. dave
  3. Slag Kustom
    Slag Kustom
    dave i have a tittle with numbers that kind of match the frame (from what i can make out). i just cant get a good rubbing of it to bring to dmv. new jersey makes you trace the vin on any car that is from out of state.
  4. Jive-Bomber
    Jive-Bomber
    MODERATOR
    Slag-
    Its going to be a Star on both ends, with A and then numbers--
    Like this:
    *A12345678*
    The Mac's Model A catalog will have more info on VIN's too.
    Check this page as well:
    http://www.mafca.com/whatyear.html
  5. Slag Kustom
    Slag Kustom
    any space between the letter and numbers ???
  6. man-a-fre
    man-a-fre
    your title wont have the stars but they are on the frame at both ends of the number as said
  7. fordcragar
    fordcragar
    from Yakima WA.
    Slag,
    Here is a picture of what the serial number would look like, from "How to Restore Your Model A" Volume 1, page 11.
  8. willysrod
    willysrod
    from upstate NY
    making a rubbing is easy, New York DMV requires it also. Just buy a set of cheap stamps (Harbor Freight), and copy the VIN you need , and punch the numbers into a section cut out from a beer can................makes a damn near perfect rubbing. Chick at the DMV said Wow this came out good !!!!
  9. Slag Kustom
    Slag Kustom
    that was my plan just did not know what it should look like
  10. fordcragar
    fordcragar
    from Yakima WA.
    Slag,
    Take a look at my last post, Ford changed the design of their stamps in 1931, as shown in the thumbnail photo. The numbers "1, 6 and 9" were different in 31, from the 28-30 stamps.
  11. Flathead Youngin'
    Flathead Youngin'
  12. Where in the world did you get this information! You don't know what you're talking about.
  13. Canuck
    Canuck
    Check out Lee Valley "WWW.leevaley.com" or Ph. 1-800-267-8767 for a "STAR" punch. They have them for $ 4.95 Cdn, part # 50K51.17. Near perfect size. They state they are not rated for use on steel, but I have used one a few times on steel and it still looks as good as new.
    Used a cheap set of 1/4" number dies that were the correct style number. Only problem was getting a good stamp, too much flex in the frame. The frame is 2 x 5 x .125 rec tube. Ended up stamping a piece of .125 steel, cutting out a piece of the frame and welding the numbered piece in.
    Just another source.
  14. fordcragar
    fordcragar
    from Yakima WA.
    If the steering box wasn't in, if it is in the way, you could clamp a solid piece of metal under the top flange of the frame and then stamp it.
