Technical Model A waterpump identifcation
Discussion in 'The Hokey Ass Message Board' started by '29 Gizmo, Nov 24, 2022.
  1. '29 Gizmo
    '29 Gizmo
    from UK
    Hi,
    I am just about to start tearing into a somewhat neglected Model A engine to see what needs attention. The water pump is a mystery. I can't seem to find any information about this design. Can anyone tell me if its a factory part or some kind of aftermarket design. There does not seem to be any access to the packing nut and rear bearing lube point what looks like a grease point at the back is a set screw. .
  2. v8flat44
    v8flat44
    Post this on The Ford Barn in the Model A section....they'll know.
    '29 Gizmo likes this.
  3. Robbie Horn
    Robbie Horn
    from Axtell
    That's a aftermarket.
  4. woodiewagon46
    woodiewagon46
    from New York
    Sometimes Model A engines were use in industrial applications such as generators, compressors etc. so that might be the case.
  5. '29 Gizmo
    '29 Gizmo
    from UK
    If its aftermarket, or later industrial application I'm hoping it has a better bearing/sealing system, as the shaft is fully enclosed. I will have a closer look when I take the cover plate off.
  6. big duece
    big duece
    from kansas
    Here is an original core to compare 20221124_111737.jpg 20221124_111749.jpg 20221124_111759.jpg
  7. v8flat44
    v8flat44
    They now make a "leak proof pump" ; a friend put one on his A.
