Model A wheel well help please.
Discussion in 'The Hokey Ass Message Board' started by speedy383, Mar 1, 2012.
  1. speedy383
    speedy383
    im trying to find out if the rear axel is suppose to line up with the center horizonal line on a model A wheel well, as of now with a 106 wheel base it lines up with the back side of the axel housing, is this correct or does the body have to be moved forward to be centered. 1930 roadster on 32 p&j frame.I'll try to post pic's thank's . .................. speedy
  2. speedy383
    speedy383
  3. charlieb66
    charlieb66
    The correct WB for an A is 103.5". I believe the rear wheelwell should line up with the center of the original A crossmember. Check the Wescott website and you will find the dimension diagrams for the A and 32 frames.
  4. The37Kid
    The37Kid
    Why would you not want the wheel & tire in the center of the wheel well?
  5. speedy383
    speedy383
    I centered the wheel in the well ,and thought the center body line in the well should line up with axel housing center line .:confused:
