Model A wheelbase?
Discussion in 'The Hokey Ass Message Board' started by woodhawg, Mar 3, 2010.
  1. woodhawg
    woodhawg
    What is the stock wheelbase for a 28 Model A Ford Roadster? TIA
  2. Crusty Nut
    Crusty Nut
    I'm pretty sure it is 103 and 1/2"
  3. Casey J
    Casey J
    from Ada. MN
    Yep, 103.5"
  4. woodhawg
    woodhawg
    Thanks for info. Mine is 107 1/4". Looks like someone added some to it along the way. There is a bump in the frame members about halfway between the front axle and the front of the body. It has a 302 Ford V8 so guess they added that to keep from remaking the firewall?
    Is that safe? Is it OK? Do I have a problem? THis is my first build.
  5. Used Up Junk
    Used Up Junk
    from Merced, CA
    It's not uncommon to stretch the front of the frame a bit for motor clearance and just 'cus it can help the proportions of a car when done right. If you are worried about the strength and safty of the frame fine someone in your area that you trust to take a look at it. I bet if you post some high quality pictures here there are more than a few guys that would take a look at it and give you some guidence! Congrats on your first build buy the way!
  6. seventhirteen
    seventhirteen
    from dago, ca
    it's ok as long as you aren't running a hood, and for future knowledge model A's all have the same wheelbase coupes, roadsters, sedans, and trucks 28-31 except for the big trucks of course
  7. woodhawg
    woodhawg
    Thanks guys. Will have a respected local builder take a look at it. No hood, just motor.
    The knowledge here is amazing.
  8. Casey J
    Casey J
    from Ada. MN
    I plan on doing the same thing on my A frame. Like Used Up Junk said, as long as it was done properly and it should be good to go.
  9. DirtyWoody28
    DirtyWoody28
    its actually 103 15/32 (to Henry's specs) but I always say 103 1/2
  10. DirtyWoody28
    DirtyWoody28
    this might help
