Model A Windshield chop/dimensional question
Discussion in 'The Hokey Ass Message Board' started by scootermcrad, Sep 14, 2006.
  1. scootermcrad
    scootermcrad
    I noticed tonight when I was looking at my 31 slant window windshield that the frame is tapered from bottom to top about 3 degress, maybe less. The top of the window frame is just slightly wider than the bottom. This is obviously going to effect my windshield chop a bit. I'm thinking I may have to add about a 1/4" to the center of the bottom arch. The top must remain the same width or it will not fit the under-visor panel correctly.
    Did anyone else encounter this with their Model A windshield frame? If so, did you do as I mentioned above, or is there an easier, more appropriate way of handling this?
  2. Idle Gossip
    Idle Gossip
    I took about a 1/4" out of the top window frame, visor, sheetmetal behind visor, and roof frame. It keep the original A pillar angles. It became evident that I had to do this once I set the roof back on minus 4 inches.
    All easy welds though, and my chop saw made nice straight cuts.
    I have no idea what other people have done......hope this helps!
  3. scootermcrad
    scootermcrad
    Thanks man! What year and model?
  4. scootermcrad
    scootermcrad
  5. Idle Gossip
    Idle Gossip
    30 Tudor Sedan..............here's a shot. Sorry the pic doesn't show the cuts.
  6. Corn Fed
    Corn Fed
    Unless you are doing a real radical cut, you should just be able to slightly knock the top of the vertical frame sections outward until they meet up with the top piece. I recommend a rubber mallet. But do it carefully. It doesn't take a lot of force to move them around.
    It appears in the pic of Idle Gossips chop that he cut the w/s frame in the center. I don't know why he went to all that work. Just cut the amount you need off the top corners (at an angle) and redrill the "L" bracket screw holes.
  7. scootermcrad
    scootermcrad
    Ahhh... okay! Didn't know if I could do that or not. That sounds like a good options. It's looking like it's only going to be about 1/2" or less.
  8. tatts
    tatts
    PLEASE PLEASE PLEASE dont cut that car without letting me help. Even just watch pm me yo nuba again ilost it
  9. scootermcrad
    scootermcrad
    Too late brotha! She's a little shorter now and lookin' good! Haven't got that window cut down yet though... nor ANY of the garnish moldings.... LOTS of work left!! :eek:
  10. Mad-Lad
    Mad-Lad
    Hey Scooter....ever get that Quickie you were talking about?
    Any progress pictures....lets see em man.
  11. scootermcrad
    scootermcrad
    Mad-lad.... I'll do an update. I was going to wait, but it might be a bit before I can get more work done, so I'll do one. Keep your eyes peeled...
