Technical Model A Windshield Frame
Discussion in 'Traditional Hot Rods' started by fairwayjc, Feb 24, 2014.
  1. fairwayjc
    fairwayjc
    I have a 31 model a coupe that I'm going to chop 3". How do I take the original glass out of the frame. Does anyone make an aftermarket frame with a 3" chop?
    Thanks for your help.
    john
  2. Dave L
    Dave L
    from Idaho
    There should be some screws at the top on the side, remove the screws, remove top part of windshield, by lifting that part up and away from the main part, once its off, slide glass out.
    Hope this helps
    Dave L
  3. cayager
    cayager
    take the top off the frame. measure down 3 inches cut off at a 45 degree angle just like the frame has now. drill new holes and presto instant chopped frame. shouldtake a total af about 5 minutes. probablt the easiest thing of the whole project.
  4. kb cookout
    kb cookout
    There are 6 bolts that hold the top of the frame on
    2 go thru the face of the frame and have a nut on the back , and there are 2 on each side edge were the gasket goes and screw into a angle bracket inside the frame
    later kb
  5. Bluedot
    Bluedot
    First, grab a hammer...:rolleyes:
