Been researching this site over the last couple weeks for info on the correct unsplit wishbone for an AV8 using a 32 K member in an A frame. There is a ton of info and one of the most informative ones is Mike Bishops thread showing how to extend the 33 wishbone with an A donor. Since I am using an A axle my question is why can't I use two A wishbones to achieve the proper length using the Bishop recipe. I took his article as a solution for all who bought the 33 34 Bones and found it they didn't quite work. It looks like to me that I can accomplish the same thing with two A wishbones followng Mike's procedure or is my geometry off thus the need for the 33 bones. Thank you in advance for any advise.
anything's possible but i dont know how you would be able to keep the constant taper look to the legs....
A member from Norway posted it with current pics. Here you go http://www.earlyford.no/phpBB2/viewtopic.php?t=600
