Model A #
Discussion in 'The Hokey Ass Message Board' started by BLACKLAC50, Jun 11, 2008.
  1. BLACKLAC50
    BLACKLAC50
    HAVEING PROBLEMS GETTTTING MY SEDAN REGISTURED ! ! i got my model a off of here from some lame @$$ who lied threw his teeth about this car now i need to find some number on this thing ""if i can "" can some one tell me the location of the vin on a 31 model a
  2. Stock original engine?
    The VIN# is found in two places.
    1. the engine number is the same as the vin if it wasn't replaced.
    2. Pull the body and look on the drivers side frame rail top rail between the steering box and body mount bolt.
  3. 50burban
    50burban
    watch your mouth boy i have the ***le on that car i told you it was inspected when i traded you for your 51 that YOU LIED about!
    i have that ***le all you did was tell me to screw off when i asked for help ***ling this 51 so why should i have helped you?
  4. Goztrider
    Goztrider
    from Tulsa, OK
    What Jr said about the frame rail.
    Sounds like we're about to witness some Urinary Olympics here.
  5. Sunday Sunday Sunday... it's the FNG ******* contest, main event at the urinary olympics...
    Anyways, a Model A doesn't have a VIN, just a serial number, and from what I've read guys have registered A's in California with a home-made frame with a correct-looking number stamped on in the correct location. It shouldn't be anything to panic over. Given there is an existing ***le for the car, you might be better off with a different number, so that you don't run the risk that the serial comes up as already in use.
