Projects Model A
Discussion in 'The Hokey Ass Message Board' started by pennafxu, Nov 9, 2010.
  1. patman
    patman
    Hard to tell from the pictures where your feet were, but...it's easier to really crank on a bolt when you are standing on the engine stand legs. If your feet are on the floor, the whole stand rolls around instead.
  2. pennafxu
    pennafxu
    from Kentucky
    yeah I had half my body and foot jammed against the stand because the whole engine felt like it was going to fall over with the torque being exerted.. :eek:
  3. themachine
    themachine
    good progress man keep it up
  4. pennafxu
    pennafxu
    from Kentucky
    Thanks...
  5. pennafxu
    pennafxu
    from Kentucky
    i believe this is a press fit... will need to grab the puller.
  6. pennafxu
    pennafxu
    from Kentucky
    shot of the removed valves (and the one that got away)
  7. pennafxu
    pennafxu
    from Kentucky
    and the rest of the left side (two valves stuck in total)
  8. pennafxu
    pennafxu
    from Kentucky
    right side valves came out without issue...
  9. pennafxu
    pennafxu
    from Kentucky
  10. pennafxu
    pennafxu
    from Kentucky
  11. pennafxu
    pennafxu
    from Kentucky
    It appears to be, but only one way to find out... That's all for now folks!
  12. pennafxu
    pennafxu
    from Kentucky
    pulling apart carb linkage...[​IMG]
  13. pennafxu
    pennafxu
    from Kentucky
    most fore linkage...[​IMG]
  14. pennafxu
    pennafxu
    from Kentucky
    return spring...[​IMG]
  15. pennafxu
    pennafxu
    from Kentucky
    okay this was connected to the go pedal... scary![​IMG]
  16. pennafxu
    pennafxu
    from Kentucky
    first spring off...[​IMG]
  17. pennafxu
    pennafxu
    from Kentucky
    both springs...[​IMG]
  18. pennafxu
    pennafxu
    from Kentucky
    vacuum hose...[​IMG]
  19. One Finger John
    One Finger John
    Have to say your do***entation is excellent. Pictures are crisp and clear. Could you tell us the make, model of camera and what lenses you used. Thanks.
    John
  20. pennafxu
    pennafxu
    from Kentucky
    Thank you :cool:
    I am currently using a Canon EOS50D, current lens is 50-180mm... Hope that helps...
  21. pennafxu
    pennafxu
    from Kentucky
    Br*** lines need to be removed for dis***embly...
  22. pennafxu
    pennafxu
    from Kentucky
    fuel pump bolts removed...[​IMG]
  23. pennafxu
    pennafxu
    from Kentucky
    body removed...[​IMG]
  24. pennafxu
    pennafxu
    from Kentucky
    Fuel pump ***y, this will be rotated 180 deg so the fuel lines wont be crossed...[​IMG]
  25. pennafxu
    pennafxu
    from Kentucky
    gasket s****ed off...[​IMG]
  26. pennafxu
    pennafxu
    from Kentucky
    my latest tool... (stolen from my wife's car)[​IMG]
  27. pennafxu
    pennafxu
    from Kentucky
    intake... devoid of all accessories...[​IMG]
  28. pennafxu
    pennafxu
    from Kentucky
    Dual carb set up, will be thoroughly inspected and cleaned. Should polish up really nicely also...[​IMG]
  29. pennafxu
    pennafxu
    from Kentucky
    Cleaned up the threads, as I was bored...[​IMG]
  30. pennafxu
    pennafxu
    from Kentucky
    Threads cleaned up...[​IMG]
