Projects Model A
Discussion in 'The Hokey Ass Message Board' started by pennafxu, Nov 9, 2010.
  1. pennafxu
    pennafxu
    from Kentucky
  2. pennafxu
    pennafxu
    from Kentucky
  3. pennafxu
    pennafxu
    from Kentucky
  4. pennafxu
    pennafxu
    from Kentucky
    Not so bad... Shop said should be an easy fix with pinning... Whatever that is...
  5. pennafxu
    pennafxu
    from Kentucky
  6. daddio211
    daddio211
    Not bad at all, looks like a totally usable block. Regarding "pinning", if they're actually referring to "heli-coil" then yes, do it. Don't let them attempt any other type of repair. Heli-coil is the only way it will last!
  7. grits
    grits
    So What's up with the gang signs, thought we already covered that Geeez
  8. pennafxu
    pennafxu
    from Kentucky
    Since you've pointed that out, let me point something out to you again. That is not a gang sign. It is called the "Shocker," please look it up. If you can't be bothered to look it up, let me kindly explain. It stands for two for the pink and one for the stink. If you don't get that still, you put two fingers up a girls pink ****** and your other finger up her brown **** hole. Hence the "pink" and "stink." The "shocker" portion is the females unexpected shock of getting the **** stimulation. Hope that clears things up...
  9. daddio211
    daddio211
    Also referred to as "shock and ahhhhhhhhhhhhh" :)
  10. pennafxu
    pennafxu
    from Kentucky
    Anyways, back to business boys... So Daddiiiiiiyoooooo! If "pinning" is not heli-coiling (a process which has saved my hiney a few times) is not the same then that's a no-go? What other block repair is there? He said he would attach some material and then deck the block for square... is that correct? I have seen people tig weld whole surfaces of blocks and do this... Why will/won't this work in my case?
    Please advise... your previous Padiwan who is now on the dark side of the force
    Darth Whiskyous...
  11. chrisntx
    chrisntx
    from Texas .
    pinning ir metals***ching is good, this is not the place for a helicoil
  12. patman
    patman
    Pinning is drilling a series of holes along the crack and putting in steel pins. The process is repeated until the pins overlap completely, then it's milled down flush again. It's a good and common way to repair cracks.
  13. pennafxu
    pennafxu
    from Kentucky
    okay that is just friggin awesome! thanks for the confirmation guys, my 8BA thanks you from the bottom of its cracked block, and cracked heads (soon to be replaced with offy's :D)
  14. pennafxu
    pennafxu
    from Kentucky
    I just used the term "crack head" in a post! lol I "crack" myself up sometimes...:D:eek::cool:
  15. Saxon
    Saxon
    from MN
    Glad to see your back at it. Your block looks like a good one.
    A pinned face. Before millin'
  16. pennafxu
    pennafxu
    from Kentucky
    Thanks for the words... Yup need to forge ahead with the build before it stagnates again... :)
  17. daddio211
    daddio211
    Thanks for the lesson fellas, great info to know!
  18. pennafxu
    pennafxu
    from Kentucky
    waiting on quote from shop... :roll eyes: took some pics of cleaned/blasted parts...[​IMG]
    Timing cover
  19. pennafxu
    pennafxu
    from Kentucky
  20. pennafxu
    pennafxu
    from Kentucky
    [​IMG]Block with mains...
  21. pennafxu
    pennafxu
    from Kentucky
  22. pennafxu
    pennafxu
    from Kentucky
  23. pennafxu
    pennafxu
    from Kentucky
  24. pennafxu
    pennafxu
    from Kentucky
    con rods will br reconditioned..[​IMG]
  25. pennafxu
    pennafxu
    from Kentucky
    [​IMG][​IMG]This machine helps with the reconditioning of the surface...
  26. pennafxu
    pennafxu
    from Kentucky
    before and after...[​IMG]
  27. pennafxu
    pennafxu
    from Kentucky
    [​IMG][​IMG] this bad boy recons the internal diameter of the con-rods that mate to the crank
  28. pennafxu
    pennafxu
    from Kentucky
    crank fluxed out ok... yippee![​IMG]
  29. pennafxu
    pennafxu
    from Kentucky
    say hello to my new wall art... [​IMG][​IMG]these didn't flux out ok...
  30. pennafxu
    pennafxu
    from Kentucky
    seeing cranks hanging everywhere was a pretty unusual sight to say the least...[​IMG][​IMG][​IMG][​IMG]
