Projects Model A
Discussion in 'The Hokey Ass Message Board' started by pennafxu, Nov 9, 2010.
  1. pennafxu
    pennafxu
    from Kentucky
    My goal was the dagels x-member which is much smaller gage steel and has pretty huge holes too... ImageUploadedByH.A.M.B.1397086747.568177.jpg ImageUploadedByH.A.M.B.1397086763.175464.jpg
  2. pennafxu
    pennafxu
    from Kentucky
    Here you can see the smaller holes I had mapped out...
  3. pennafxu
    pennafxu
    from Kentucky
    I also chamfered the holes...
  4. patmanta
    patmanta
    from Woburn, MA
    Good call. 3/16" may seem thick and strong, but you can hand bend a piece of flat (if it's long enough). The ridge on the angle is what keeps it strong in the way you're using it. If you look closely at the dagels X member, you'll see that the holes are big, yes, but the distance from the edge of the hole to the bottom of the rail is much greater, more like the 2.75" holes you've got laid out.
    I'm not sure where most of the flex and force tends to ac***ulate on a X member like you're building, but if it ends up being those pieces, you may eventually develop tears in the metal.
  5. pennafxu
    pennafxu
    from Kentucky
    Thanks for the input man! The 2.75" holes look great also!
    ImageUploadedByH.A.M.B.1397171451.956614.jpg ImageUploadedByH.A.M.B.1397171461.105498.jpg
    ImageUploadedByH.A.M.B.1397171484.022478.jpg ImageUploadedByH.A.M.B.1397171495.472863.jpg
    Got em' all drilled in half the time too like you advised! More pics to follow and more mocking, welding and fitting!
  6. pennafxu
    pennafxu
    from Kentucky
    Starting cleaning up the pieces... ImageUploadedByH.A.M.B.1397252606.878849.jpg ImageUploadedByH.A.M.B.1397252616.625372.jpg
    Need to fit them precisely for welding.
    ImageUploadedByH.A.M.B.1397252639.629238.jpg ImageUploadedByH.A.M.B.1397252646.945822.jpg
  7. pennafxu
    pennafxu
    from Kentucky
    Nice little cut outs... ImageUploadedByH.A.M.B.1397308782.029313.jpg ImageUploadedByH.A.M.B.1397308791.140784.jpg
    Can use them for something I'm sure!
  8. pennafxu
    pennafxu
    from Kentucky
    Final grinding/belt sanding for perfect fitment...
  9. pennafxu
    pennafxu
    from Kentucky
    Right angle square used for alignment...
  10. pennafxu
    pennafxu
    from Kentucky
    Clamped, tacked, welded, cleaned and ready!
  11. pennafxu
    pennafxu
    from Kentucky
    ImageUploadedByH.A.M.B.1397331516.057433.jpg ImageUploadedByH.A.M.B.1397331525.397421.jpg
  12. pennafxu
    pennafxu
    from Kentucky
    ImageUploadedByH.A.M.B.1397331678.478714.jpg ImageUploadedByH.A.M.B.1397331687.357451.jpg ImageUploadedByH.A.M.B.1397331693.514224.jpg ImageUploadedByH.A.M.B.1397331712.217611.jpg ImageUploadedByH.A.M.B.1397331752.419670.jpg
    One side done!
  13. pennafxu
    pennafxu
    from Kentucky
    Need to finish the other side...
    ImageUploadedByH.A.M.B.1397331840.463309.jpg ImageUploadedByH.A.M.B.1397331854.647737.jpg ImageUploadedByH.A.M.B.1397331866.034391.jpg ImageUploadedByH.A.M.B.1397331877.049847.jpg
    Ooh this is tiring!
  14. pennafxu
    pennafxu
    from Kentucky
    Need to finish the other side, and weld up the insides... ImageUploadedByH.A.M.B.1397331942.614358.jpg
  15. harley jim
    harley jim
    lots of hours but it looks great
  16. pennafxu
    pennafxu
    from Kentucky
    Thank you man...
    Other side welded up...
    Need to figure the areas to splice into the frame...
  17. pennafxu
    pennafxu
    from Kentucky
    Measuring 2.5" stock for the center portion...
    Plasma cut one of the sides to make a u-channel.
  18. pennafxu
    pennafxu
    from Kentucky
    Rubber trans mount will bolt here... ImageUploadedByH.A.M.B.1397527888.650024.jpg
  19. pennafxu
    pennafxu
    from Kentucky
    Welded up the insides of the x-member pieces... ImageUploadedByH.A.M.B.1397527952.182566.jpg
  20. pennafxu
    pennafxu
    from Kentucky
    Taking more measurements...
    ImageUploadedByH.A.M.B.1397684537.754449.jpg ImageUploadedByH.A.M.B.1397684553.336060.jpg
    Want it square to transmission
  21. pennafxu
    pennafxu
    from Kentucky
    Side view...
    Writing down as I go...
    Using the frame for as many reference points as I can. ImageUploadedByH.A.M.B.1397684705.626810.jpg
    7 weld points... And I will use a rosette on top...
  22. pennafxu
    pennafxu
    from Kentucky
    Left side in place...
    Need to trim front a little for better alignment...
  23. pennafxu
    pennafxu
    from Kentucky
    Decided to raise the engine 6-10"
    Using the rubber mounts from speedway which requires the needed elevation...
    Can't decide on the final height...
    3.5 deg pinion angle...
  24. pennafxu
    pennafxu
    from Kentucky
    ImageUploadedByH.A.M.B.1397869602.213943.jpg ImageUploadedByH.A.M.B.1397869608.588160.jpg ImageUploadedByH.A.M.B.1397869616.039848.jpg ImageUploadedByH.A.M.B.1397869624.269070.jpg
    Thanks Joe! You are the man!
  25. Outback
    Outback
    from NE Vic, Oz
    Thanks for all the info n pics!
    Sent via carrier pidgeon & smoke signals with the HAMB App
  26. pennafxu
    pennafxu
    from Kentucky
    You are very welcome! Will be ***embling the front end here soon, and tacking in engine mounts!
  27. pennafxu
    pennafxu
    from Kentucky
    Man I have gotten busy with work!! Real work!! This really ****s man… I hope to put in a few hrs this week… Nothing major, maybe re-***embly of the front end...
  28. daddio211
    daddio211
    Wow man! I'm gone working and look what you accomplished!!!
  29. pennafxu
    pennafxu
    from Kentucky
    Thanks man... Just don't have the mojo to work on this right now, plus work and kids school is kickin my ***! Need to chip away again but Just don't feel it right now! I'm gettin bored! Not good :(
  30. patmanta
    patmanta
    from Woburn, MA
    You gotta find something else to put your mind to for a couple weeks or so when you get to feeling that way. For me it's video games when I want to tune out. I beat one or two games, then I'm ready to do something constructive again.
