Projects Model A
Discussion in 'The Hokey Ass Message Board' started by pennafxu, Nov 9, 2010.
  1. Pennafxu/Whisky,
    I love this thread, and the pic of you looking tired and flipping the bird after getting the body off the frame had me rolling with laughter! Good luck, and keep it up!
    Brent
  2. pennafxu
    pennafxu
    from Kentucky
    Thanks... I was tired! Back from vaca, now need to hit the rod hard...:D
  3. pennafxu
    pennafxu
    from Kentucky
    Ok after further reading, Need to ditch the whole rear suspension, rear end, second trans...
    Current to do list:
    Build a wooden body dolly
    Lift engine and Trans...
    Unbolt 2nd trans
    Re-check frame again for square...
    Fish tail every seam.
    Weld in a x-member
    Re-weld new trans mount
    Set up/order a new rear end and rear susp set up... (front end looks ok)
    Rear leaves are just ****ed.
    Blast body and frame...
    clean/blast engine...
    C-notch and box front frame rails, as suspension is sig lowered... Also if caster is less than 7 deg, its bye bye current front set up or re-working it!
    AND WAIT FOR IT, WAIT FOR IT!!!!
    DITCH THE GRILL! YOU MOTHER ****ERS HAVE WORN ME DOWN!
    I plan to make a louvered 3 piece hood for this *******, and that grill just won't cut it... I need a lower grill to match the cowl, so the hood will flow. I need to check the radiator height, and may have to go with a new/or mustang style...
    So far everything is flathead f600 (engine, trans, and radiator)....
    Any ideas on rear end folks?
  4. crotex
    crotex
    from cuero, tx
    look like you are making some progress
  5. patman
    patman
    ...and there was much rejoicing...
  6.
  7. pennafxu
    pennafxu
    from Kentucky
    Trying...
    After further reading... The front suspension is a gonner too!
    I HATE RAT RODS!!!!!!:mad:
    AAAARGH!!! :mad:
  8. puckm2
    puckm2
    Is the grill for sale?
  9. ClayPigeonKiller
    ClayPigeonKiller
    You have ****ing problems.
  10. pennafxu
    pennafxu
    from Kentucky
    Check out ebay in a week or so...
  11. Why don't you sell me that dangerous WWII gas tank. I guess I could take that road hazard off your hands. PM me.
  12. pennafxu
    pennafxu
    from Kentucky
    PM sent holmes...
  13. pennafxu
    pennafxu
    from Kentucky
    or PM me to work out a deal. I paid top dollar for it and need to recoup or will mount in the garage...
  14. garagerods
    garagerods
    from Omaha
    your a brave soul.
    could be really cool....
    good luck!
  15. pennafxu
    pennafxu
    from Kentucky
    Thanks! More luck Dumb ****in idiot... :rolleyes:
    I just love this kinda stuff! Have got all my **** ready to order...
    Looking for a S10 transmission to slap behind the flathead with a cornhusker kit...
  16. pennafxu
    pennafxu
    from Kentucky
    Ok back to work!! The weather outside is frightful, the fire is so delightful, there's really no where to go, let it HAMB, let it HAMB let it HAMB!
    Hand made dolly using wood laying around and Simpson Strong Ties.
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  17. motorgod7
    motorgod7
    from chico,ca.
    Wow, just read this from the begining. Looks like you bought a good engine, out of a rat rod. Best of luck to you. Look up H.A.M.B.er, KOOLKEMP's metal work if you get discouraged with the body work you have in store for the future.
  18. pennafxu
    pennafxu
    from Kentucky
    Thanks for the words...
  19. rick finch
    rick finch
    Ahhhh, good man! (One of the few times the screaming horde was right.);)
  20. olskoolrodder
    olskoolrodder
    my preference is '35 Ford wires all around (16" dia.) with 5 / 5.25 x 16 wide whites on the front and 8.20 x 16's in the rear. I believe that is very close to what your photoshop photo has early on in the thread.
  21. pennafxu
    pennafxu
    from Kentucky
    Need help from the community...
    Please help me ID my transmission... It is a 53 4-speed mated to the original 53 flathead power plant. I want to rebuild this and potentially replace spur gears with helical gears if such a kit exists.
    Thanks!
  22. pennafxu
    pennafxu
    from Kentucky
    Had a ****ty day at work...
    so I drank one of these and got going on the chumster... Ahh yes the nectar of the gods... obviously went with a smaller serving size and not my regular 4 gallon can that causes immediate cardiac ventricular fibrillation.
  23. pennafxu
    pennafxu
    from Kentucky
    took the grille off and put it in the "to go" pile...
  24. pennafxu
    pennafxu
    from Kentucky
    Rear end removed... will salvage the metal tubing and the rest to the s**** yard...
    [​IMG][​IMG]
  25. pennafxu
    pennafxu
    from Kentucky
    Driveline slipped off 2nd transmission spline without issue...
  26. pennafxu
    pennafxu
    from Kentucky
    rear end looks kinda bare without the rear suspension.... :(
    but don't worry back end of frame I have shiny bits coming your way...
  27. pennafxu
    pennafxu
    from Kentucky
    now u see it...
    now u don't :)
    that sonofa***** flathead radiator weighs a ****in ton, and I always forget it. The ******* caught the back side of my arm and s****ed the **** out of it...
  28. pennafxu
    pennafxu
    from Kentucky
    ripping into the front suspension...
    have fun while it lasts suspension mounts as ur ***es are gonna get the plasma chop! u ****ers!
  29. pennafxu
    pennafxu
    from Kentucky
    race jack in place to maneuver front end...
    [​IMG][​IMG]
  30. pennafxu
    pennafxu
    from Kentucky
    left side link removed...
    and right side...
