Projects Model A
Discussion in 'The Hokey Ass Message Board' started by pennafxu, Nov 9, 2010.
  1. pennafxu
    pennafxu
    from Kentucky
    Yes Sir,
    This may not work for me due to my frame design, or lack of it! I have a good idea in mind however. I appreciate the help...
    Stogy likes this.
  2. patmanta
    patmanta
    from Woburn, MA
    I'm late to the party on the panhard issue. Yeah, do that differently. At a minimum, go with a J-Bar and lower/higher mounting points I'd say.
    Also, that flat plate spring mount keeps jumping out at me. The plan is to gusset that, right?
    You are brave welding in those track pants, LOL!
    Stogy and pennafxu like this.
  3. pennafxu
    pennafxu
    from Kentucky
    -For sure on high/low mounts
    -absolutely more to come on that
    -Tons of gussets to come
    -Couple things here... with TIG the heat is very localized so you don’t get nailed with goops of melting material... my biggest issue is getting touched with the hot welding rod... Ouch!
    Stogy and patmanta like this.
  4. patmanta
    patmanta
    from Woburn, MA
    I'm mostly just rattling your cage. I used a drilled out 2x4 and several C clamps for a perch mockup at one point ;)
  5. Tim_with_a_T
    Tim_with_a_T
    Going back through my build thread in search of reference material was somewhat embarr***ing to see the various attempts I made, but that's part of learning I guess. What I ended up with is this mount on the p***enger's side axle:
    And this bracket on the frame driver's side:
    Kinda sorta overall idea:
    Conceptual sketch. The panhard goes through the ladder bars and dips below the pumpkin for clearance. The brackets on each end have multiple holes for adjust-ability as clearances are tight, and one end of the bar is threaded for these changes in adjustment.
    Not super easy to follow, but a picture of current state (minus the newly formed dust):
    I think you could do something similar. If nothing else, hopefully it gets your brain juices flowing. Carry on!
  6. Tim_with_a_T
    Tim_with_a_T
    I really need to get back on my project.... if needed I could probably be persuaded to roll it outside for some better photos. I like what you're doing with your build by the way. Keep it up.
    patmanta, Stogy, OFT and 1 other person like this.
  7. Dean Lowe
    Dean Lowe
    Anyone who wants to know what well thought out suspension looks like, just look at the photos Tim posted. Nice workman ship too.
  8. pennafxu
    pennafxu
    from Kentucky
    Thank you for taking the time out to post this...
    Stogy, OFT and Tim_with_a_T like this.
  9. pennafxu
    pennafxu
    from Kentucky
    Yes Sir...
    Stogy likes this.
  10. pennafxu
    pennafxu
    from Kentucky
    Few ways to skin this cat...
    [​IMG][​IMG]
  11. pennafxu
    pennafxu
    from Kentucky
    Thanks
    Stogy likes this.
  12. pennafxu
    pennafxu
    from Kentucky
    Took some measurements and laid out some templates...
    [​IMG][​IMG][​IMG][​IMG]
    12” is the measurement so I’m going to split the difference...
    It’s roughly 15” from center axle to the ground. This measurement was taken to make sure the bar is even to the ground on either side.
  13. pennafxu
    pennafxu
    from Kentucky
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Luckily the piece of steel was 24” long... so 4 templates were laid out. However each piece needs to be about 1” longer to center the holes at 6” dead... so that kinda stinks, but oh well. I can get 3 mounts from a single strip.
    Tim_with_a_T likes this.
  14. harley jim
    harley jim
    Pennafxu Im still lurking here and watching. Keep up the good work.
    Sent from my smart*** phone when it wants toThe H.A.M.B. mobile app
    pennafxu likes this.
  15. 1-SHOT
    1-SHOT
    from Denton
    IMG_2336.jpg i noticed you measured from the floor, this only makes your car as straight as the floor. You really need a Datum Line to measure off or a surface plate. Center Line gauges work great and you can set a datum line off them.
    brEad and pennafxu like this.
  16. abonecollector
    abonecollector
    I skipped a bunch of pages(basically from 10 to 79) just to see where this was going to end up, I got to say, Im pleasantly surprised to see it taking the right direction. I see enough of that scary half-***ed rat rod **** in person, sometimes i look at it just to see how ****ty a "car" can be built. Sometimes, I'm even lucky enough to listen to the builder boasting on his "creativity". Ill keep following this one, because i like the fact that you're un-doing the rat ****. Good job
    kidcampbell71 and pennafxu like this.
  17. 1-SHOT
    1-SHOT
    from Denton
    I am following and enjoying you take a Sows Ear and makeing a Silk Purse out of it . Anything to keep the rays off you when Tig Welding is important, there is no smoke off lt like stick Rods to help shield the rays.
  18. pennafxu
    pennafxu
    from Kentucky
    Thanks!
  19. pennafxu
    pennafxu
    from Kentucky
    Waiting on me uncle.... Uncle Max that is!
  20. goldmountain
    goldmountain
    It has been one year. What's new?
  21. pennafxu
    pennafxu
    from Kentucky
    Lots of planning!! Since Covid/being a doctor I’ve been working 20 hr days. My life ****s. I need a break. So I’ve decided to H.A.M.B. it up again.
  22. Dick Stevens
    Dick Stevens
    Thanks for all that you and the other health care workers are doing during this time! You have to take care of yourself so that you can continue to take care of the public, so make sure you take the time needed to unwind from the daily stresses. If that includes some small progress on your project great, if not it will still be there when things settle down.
    Dean Lowe, pennafxu, OFT and 2 others like this.
  23. patmanta
    patmanta
    from Woburn, MA
    Glad to see you back at it! I don't envy your workload; it's good you're finding some release/relief in your project again for sure.
  24. pennafxu
    pennafxu
    from Kentucky
    Thank you!
  25. pennafxu
    pennafxu
    from Kentucky
    So I acquired an original 33 coupe body as they have seemed to have grown on me! I’m currently in 2 minds... chop it and put it on my current ch***is... or chop the original T and put it on my ch***is. The speedster is off the table. As I believe it’s a way to cheat my way out of putting in the hard work of restoring the T body. Finally build the T and build another hot rod 33 3 window on a 33 frame. I really want a running car so I am restoring both bodies.
    I started de-skinning a partial door...
    patmanta likes this.
  26. pennafxu
    pennafxu
    from Kentucky
    I have the other part of this door.
    IMG_1060.JPG IMG_1061.JPG IMG_1062.JPG IMG_1063.JPG IMG_1064.JPG IMG_1065.JPG
    OFT likes this.
  27. pennafxu
    pennafxu
    from Kentucky
    I will be deleting the middle hinge to fit the chop... IMG_1066.JPG IMG_1067.JPG IMG_1068.JPG IMG_1069.JPG
    Spot weld drill bits...
  28. pennafxu
    pennafxu
    from Kentucky
    Finally apart...
    Door skin, only the top will be used...
    Innerds
    brEad likes this.
  29. patmanta
    patmanta
    from Woburn, MA
    I would save that 33 for a 33/34 frame and build it that way after you get the T on the road.
    You've been building this ch***is for a T body all along so putting the T body down on it will be the best path towards having a nice hot rod on the road sooner than later.
    Outback and Dick Stevens like this.
  30. pennafxu
    pennafxu
    from Kentucky
    I figured as much that you would say that. Hey what's better than a hotrod? 2 I guess!
