Projects Model A
Discussion in 'The Hokey Ass Message Board' started by pennafxu, Nov 9, 2010.
  1. pennafxu
    pennafxu
    from Kentucky
    and voila! the whole front suspension should come on outta' there! :)
    What? no picture you say? that's because...
  2. pennafxu
    pennafxu
    from Kentucky
    The damn front suspension is welded to the frame!:mad:
    I HATE RAT RODS! ARGHH! I dont feel like pulling the grinder/drill bits cutting wheels out tonight... **** it I need a break...
  3. Pensive Scribe
    Pensive Scribe
    Sure a good thing you are seeing that it never hits the road the way it was. Scary!!!
  4. pennafxu
    pennafxu
    from Kentucky
    yeah no doubt...
  5. pennafxu
    pennafxu
    from Kentucky
    so I decided to charge on and try and pull engine-trans1-trans2 in one sitting... time to undo a bunch of wires and bolts... here's a side shot of the pos cable going to the starter (I ***ume)
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  6. Keep truckin on it. I'm fixing a poorly built 'rat rod' for a customer right now. The previous builders used as much junkyard parts they could find and were NOT welders/fabricators or engineers by any means. They didn't believe in jam nuts, so they welded everything. The frame was horrible. The body is another story in itself. He bought it like that, drove it, got scared, called me, and now I'm building it the right way for him.
  7. pennafxu
    pennafxu
    from Kentucky
    I feel ya... I almost wish I had started from ground zero, but I like reverse engineering and I have an idea now of how this thing will go back together again with quality parts, engineering and my **** zero tolerance for poor workmanship. This is almost a dummy run de-mock up. Oh well live and learn I guess... :)
  8. pennafxu
    pennafxu
    from Kentucky
    clutch linkage dis***embly... These jam nuts took forever to take off... thank you ratchet wrench designing engineer may you live a happy and prosperous life!
    [​IMG][​IMG][​IMG]
  9. pennafxu
    pennafxu
    from Kentucky
    ok I'm officially tired... will pull driveline tomorrow so took snapshots of what all needs undone... Engine mounts... front and rear[​IMG][​IMG][​IMG][​IMG]
  10. pennafxu
    pennafxu
    from Kentucky
    Trans 2 mounts...
    [​IMG][​IMG]
  11. pennafxu
    pennafxu
    from Kentucky
    Is this the e-brake??
    [​IMG][​IMG][​IMG]
  12. pennafxu
    pennafxu
    from Kentucky
    side of trans-1
  13. pennafxu
    pennafxu
    from Kentucky
    trying to ID trans...
  14. pennafxu
    pennafxu
    from Kentucky
    After some scrubbing...
  15. pennafxu
    pennafxu
    from Kentucky
    That's better... T98 148 J223
    appears to be a BW T-98 need to open her up to be sure and count teeth as the T18 used the same stampings on the case...
    The site cited below has been an excellent resource, and is where I will buy my rebuild kit from...
    http://www.novak-adapt.com/knowledge/t98.htm
  16. Pat Pryor
    Pat Pryor
    i think you can see y people on here calld that a ratrod now. everything is badly engineered. but good for you going about this the right way. it must **** tho throwing away most of the parts, not that there good anyway.
  17. daddio211
    daddio211
    Do some research before you buy from them. There's a guy by the name of Chris Novak that's been taking money from hot rodders for years and not delivering anything. Make sure he's not involved, it may just be a coincidence.
  18. daddio211
    daddio211
    The one site that used to have LOTS of info on Chris Novak has removed it... lawsuit, likely. I talked to a friend of mine who builds Jeeps and he says Novak Adapt is the cats meow, so unlikely related. Theres also a number of posts regarding Novak Adapt here, so I can only surmise that these are good people.
    They're in my state, but couldn't be further away at 400 miles. Otherwise I'd drop in and check 'em out for you. I'm sure there are others here who could recommend them as well.
  19. pennafxu
    pennafxu
    from Kentucky
    yeah no doubt... painful
    Thanks man!
  20. pennafxu
    pennafxu
    from Kentucky
    getting ready to pull driveline...
  21. pennafxu
    pennafxu
    from Kentucky
    WHAT THE HELL IS THIS HOLE FOR? DOES IT NEED A SLEEVE?
  22. pennafxu
    pennafxu
    from Kentucky
    WHY IS THERE A ***** STICKING OUT THE SIDE OF THE ENGINE? IS THIS SOME KIND OF H20 PUMP OVERFLOW TUBE?
    [​IMG][​IMG]
  23. pennafxu
    pennafxu
    from Kentucky
    PLAN TO LOWER THE ENGINE AND PUSH IT BACK 2FT OR SO. THIS WAY MY HOOD PLANS WILL WORK OUT. IT SITS TOO HIGH RIGHT NOW...
    [​IMG][​IMG][​IMG]
  24. pennafxu
    pennafxu
    from Kentucky
    **ARE FLATHEAD HEAD BOLTS ONE TIME DEALS OR CAN THEY BE RE-USED?**
    [​IMG][​IMG]
  25. pennafxu
    pennafxu
    from Kentucky
    okay back to work... grinding the bolt head holding the front end on the frame...
  26. pennafxu
    pennafxu
    from Kentucky
    Front end gettin loose...
    [​IMG][​IMG][​IMG]
  27. pennafxu
    pennafxu
    from Kentucky
    glovin up to **** up the front end...
  28. pennafxu
    pennafxu
    from Kentucky
    and away we go...
    [​IMG][​IMG][​IMG]
  29. pennafxu
    pennafxu
    from Kentucky
  30. pennafxu
    pennafxu
    from Kentucky
    frame sans front end...
