Model B 4-Banger flywheel torque specs
Discussion in 'The Hokey Ass Message Board' started by KANE MCAFFER, Apr 26, 2013.
  1. Working Class Zero
    Working Class Zero
    Looking for tourque specs on model b 4 banger flywheel bolts and bell housing and trans case bolts too. Any body know or have a good link? I could only find the model a flywheel is 65 foot pounds, is the B the same?
  2. MATACONCEPTS
    MATACONCEPTS
    Oh ****!!! There's torque specs?
    To tell you all the truth, HeadBolts is the only torque spec I bother with. And that's pretty much with any car. Just bolt down evenly & clean of debre/obstuctions
    Bolts should have safety wire though.
  3. bobss396
    bobss396
    65 ft-lbs sounds safe and sane to me. I really have torqued very few in my day though.
    Bob
  4. Don't forget the 4-holed disc that goes under the flywheel bolts to hold the dowels in.
  5. 4-port Riley
    4-port Riley
    Yes, 65 lbs. if using stock or V8 bolts. I don't recommend using Model A bolts as they are old and abused. V8 bolts are much better. If using anything else be sure they are not too long and s****e on the slinger and rear main cap.
  6. Crazydaddyo
    Crazydaddyo
