model t brakes
Discussion in 'The Hokey Ass Message Board' started by conn.rod, Dec 4, 2008.
  1. conn.rod
    conn.rod
    from atlanta
    Hey guys,I don't post here alot but I do buy stuff as I need it.I know alot of you guys are a wealth of knowledge so here is my question-
    I have the opportunity to buy a model T axle assembly hub to hub for a good price but what can I use for brakes or can I sub the hubs with something different so I can use drum brakes?What wheels can I mount on the front as well?
    Thank You in advance too all who can help.Scott
  2. conn.rod
    conn.rod
    from atlanta
  3. 28hiboy
    28hiboy
    from Milton, Fl
    Not a great idea. Go with atleast a Model A axle and juice brakes. Gives you more options and parts range. Good luck and happy hunting!
  4. chaddilac
    chaddilac
    Get a model A or a 30-40s axle... don't bother with the T axle!
  5. pasadenahotrod
    pasadenahotrod
    from Texas
    The brakes on T rear ends are just emergency/parking brakes. The pre-26 ones actually use cast iron shoes with NO linings.
    The actual brakes on Ts are in the transmission.
    Best to use A stuff with 39-48 hydraulics if you want real brakes.
  6. conn.rod
    conn.rod
    from atlanta
    thanks for the help fellas.
