Model T Dash - Your Opinion Please
Discussion in 'The Hokey Ass Message Board' started by Bib Overalls, Jan 5, 2008.
  1. Use the aluminum panel.
    18 vote(s)
    60.0%
  2. Save the panel for another project.
    12 vote(s)
    40.0%
  1. Several years ago I traded with a friend for a cast aluminum six gauge dash panel. It was the first part I aquired for my current 26 Model T sedan build.
    Yesterday I used the panel as a template to cut the gauge holes in the dash.
    I've set the gauges in place with and without the aluminum panel. I really want to use it. But I am concerned that it will be "to much" for the relatively small T dash board. What do you think.
  2. steel rebel
    steel rebel
    good look keep it!
  3. v8 Bake
    v8 Bake
    My opinion,T's were plain and simple with no frills. I like'm that way
  4. How would you fasten the little panel to the dash? Will the gauges alone hold it? That way you could try it out w/o drilling holes in the dash.
    Thanks,
    Kurt
  5. tkvalead
    tkvalead
    I like the look. Nice job.
    thomas:)
  6. Wildfire
    Wildfire
    You're right, its too much. You should send it to me...
    ***uming the dash will be painted, I think it will look fine.
  7. oldspert
    oldspert
    from Texas
    It will be polished and turned hopefully. Of course, It will look good if the rest of the interior is spit and polish too. If not, just the stock T dash is the way to go.
  8. The little panel is up-side-down though :eek:! The curved edge should be on top.
  9. chaddilac
    chaddilac
    I think it looks good with the panel, looks too plain with only the gauges stuck in the dash.
  10. madpole
    madpole
    i think use the panel. when it is painted, the aluminum will break it up nice. it is almost too smooth without it, in my opinion.
  11. The Insert looks good, but you might try doing something with the center of it- engine turning, paint, etc to blend it in better.
  12. We filled the '27 T dash and used a Haneline 1932 machined turned insert and mounted a 3 3/8 speedo and a 4-in-one 3 3/8 guage.
    Using a Moon Tach on the column.
    Nice & Simple!
  13. Unkl Ian
    Unkl Ian
    So go ahead.
  14. willys_truck
    willys_truck
    use it, but i would look good engine turned
  15. Lucky Burton
    Lucky Burton
    I agree.....Use it with the dash painted black.....Lucky
  16. The gauges will hold it on just fine.
    Mr. Bibb, before you decide, shoot some primer on the dash so you have a contrast between panel and dash.
    Right now, imo, it's hard to tell with both metals being so close in color,
    Nice part is, if you do use it and get tired of it, no big deal to pull the instruments, remove the panel and go back to a plain painted dash.
    Although a little paint touchup would be required due to panel wear on the dash.
  17. pigpen
    pigpen
    from TX USA
    I think I like the use of the panel best, although it looks good without it also. I spread my gauges out a bit more and covered my wavy hammer welding with the upholstery material. (The hyde if the mighty Nauga). Your work bench looks entirely too clean! Disgusting! pigpen
    I have seen the Auburn dash used in the '27 T. That looks fantastic! The fibergl*** one for Model A's from Wescott's can be trimmed to fit.
  18. Von Rigg Fink
    Von Rigg Fink
    from Garage
    I really think you should just give it to me..It will not look right in your T...he he he
    Kidding..do what you want ..its yours
  19. bulltown_boy
    bulltown_boy
    Use the panel or reposition the guages.
  20. I like it
    This is what I did to mine
