Model T Fuel Tank Capacity?
Discussion in 'The Hokey Ass Message Board' started by Harrison, Nov 25, 2008.
  1. Harrison
    Harrison
    Can anyone tell me the capacity of these Model T fuel tanks? The first is a 1910-1911 "torpedo" tank. The second is a 1920-1926 "oval" tank.
    Thanks, Jim
  2. Strange Agent
    Strange Agent
  3. Strange Agent
    Strange Agent
  4. 61bone
    61bone
    I have a oval tank that takes 7 1/2 gallons when i run out of gas.
  5. side_valve
    side_valve
    Alliance Vendor
    The big one is approx. 16 gallons. (25.5" x 14" x 14")
    The oval tank is about 10 gal. Unless you get one of my "special" extended versions.
  6. lindross
    lindross
    Don't know about the top tank, but he oval tank looks exactly like the ones we use on our roadsters. I believe they are ~8 gallon tanks.
  7. the-rodster
    the-rodster
  8. Give me some dimensions and I can calculate the capacity in gallons.
  9. Von Rigg Fink
    Von Rigg Fink
    from Garage
    a cubic foot =7.48 gallons...1,728 cubic inches
    Volume =Pi over 4, X d2h.....d is diameter, h is height, PI is 3.1416..use all corresponding measurments...if inches stay in inches..if in feet stay in feet..etc..
  10. Von Rigg Fink
    Von Rigg Fink
    from Garage
  11. Harrison
    Harrison
    Does this one come with the mounting straps/feet like pictured above? I didn't see them on your website.
    Thanks, Jim
  12. side_valve
    side_valve
    Alliance Vendor
    I can get one made like that but I do not recommend it. Those straps are riveted to the tank - that means mounting brackets are part of the tank. Even a little frame or body flex could compromise the structure of the tank. The one I like to sell does not have the mounting straps riveted to the tank and I feel is a little bit safer. Here’s a pic of some mounting straps a customer fabricated for mounting the big tank:
