Model T question
Discussion in 'The Hokey Ass Message Board' started by laverda, Dec 19, 2006.
  1. laverda
    laverda
    I have a lead on a Model T coupe (never did find an A coupe after selling my A sedan) and need some help ***essing the car. I am only looking at the body.
    -are there critical areas on a T coupe that need to be somewhat intact to salvage?
    -what was the thickness of the original sheet metal? I plan on taking a close look (measurements if possible) to see how much is left before making any offer.
    -any key T parts to look for?
    Any help would be great. Thx and enjoy xmas out there.
  2. Nothing much special in terms of ***esment that you wouldn't do for any other car. ***uming your talking about a 26/27 here is some info:
    1. Sheet metal thickness was approximately 19ga.
    2. Decklids are rare and tend to be expensive. There are some aftermarket inner panels but they ****..
    3. Doors are expensive and even more rare than the decklid. They interchange with model A pickups and it seems there are less doors than cars. Patch panels are readily available..
    4. Most patch panels are readily available. I don't believe full quarters are but that's about all that isn't available that you couldn't easily fabricate.
    5. These years of T have a very decent steel substructure unlike prior years which used wood. Good jambs and subrails will provide a good base for your build.
    Good luck. Let me know if you need any help or advice.
